Joenowlost Occasional Visitor
Posted: Thu Aug 24, 2006 12:21 am Post subject: |
After two weeks of owning a Nuvi 310 and the GTM12 traffic receiver I still have not had the pleasure of ANY traffic information from the £400 piece of equipment. I was however pleased to see that Garmin are on the case with the firmware updates - the latest as of today included a number of critical improvements......
...Whilst not receiving traffic updates sat in a traffic jam I can comfort myself with the knowledge that as a priority they have managed to "Remove off-road bearing line" and "Add verification step to Garmin Lock Pin entry" in the latest update!!
I guess the next priority will be to change the selection of background splash pictures... 8O |
hawk74 Occasional Visitor
Joined: May 14, 2006 Posts: 17 Location: East Yorkshire
Posted: Thu Aug 24, 2006 12:34 am Post subject: |
Sorry firmware version is 2.9
Have tried it, no luck. Although they have removed the search button from the traffic option in system menu.
I might try and get hold of a ferrite ring and try it myself. If someone gets one from Garmin please can you post a picture of it with dimensions. |
cdmackay Lifetime Member
Posted: Thu Aug 24, 2006 3:30 am Post subject: |
thanks, I do get some traffic alerts listed,, so perhaps am OK. Had wondered whether perhaps I was missing some, but if it's a case of all or nothing, then that's looking good.
I've also just upgraded the 360, so that should get transferred over next time I'm in the car. |
Ali3 Occasional Visitor
Posted: Thu Aug 24, 2006 6:46 pm Post subject: |
I've had a 310D for a week. TMC works fine around the M25 but no TMC in or around Farnham & Guildford which is where I really want it to work. Spoke to Garmin yesterday (after holding for more than 40mins) and they sent me a ferrite for the power lead. They also told me to attach the aerial about 5" up from the bottom of the windscreen. Right in my line of sight!
Anyway, this has not improved anything. The instructions show the ferrite is designed to supress noise on an aerial feed for a different product.
So, took back to Halfords today and showed them the system didn't work in their car park (Farnham). The guy there is helpful but is clearly paid to do anything in his power to avoid giving me my money back. Instead he gave me a brand new 310D which doesn't work either. Given that I can show him it doesn't work in his carpark I guess he has no choice but to issue a refund. I'm looking forward to the argument which I will have in 10 mins!
Given that the system works in london and around the M25 my conclusion is that its simply not sensitive enough to pick up a good signal anywhere around Guilford, and from the posts I've read on this forum it looks like there are other blackspots around the country too. The only way I can imagine this system working everywhere is with more radio stations transmitting the signal. Garmin & Halfords should make it clear there is a limited service. Prospective buyers beware |
JT-Mech Occasional Visitor
Posted: Thu Aug 24, 2006 9:53 pm Post subject: |
Looks like there is a GTMxxx update, it came up on the webupdater, but 2.9 didn't 8O Unless I didn't do the GTMxxx last time |
Posted: Fri Aug 25, 2006 1:18 pm Post subject: |
I thought I'd give Garmin another try before taking the 310D back. They sent me though a map showing the location of all transmitters in the UK. Most of the south east is covered but Farnham is in a bit of a void. Other areas without transmitters close by are south and mid wales, lincolnshire, carlisle, dorset, southern scotland...etc. It would be worth calling them and getting this map if you have some problems. |
n4nick Regular Visitor
Posted: Fri Aug 25, 2006 1:33 pm Post subject: |
Hi Ali3
Would it be possible for you to scan this and post a link on the thread?
Cheers - Nick |
faujasite Occasional Visitor
Posted: Fri Aug 25, 2006 5:35 pm Post subject: |
I asked Trafficmaster what the situation was with the GTM12 and received the following reply:
Quote: |
Thanks for the email.
It has been brought to my attention that the new GTM12 antenna is not
performing adequately, this is currently being investigated.
There were no problems with the GTM11 if you are able to source one.
As soon as a resolution is concluded I shall be in contact.
Kind regards
TrafficMaster Plc
Looks as if it would not be wise to purchase a GTM12 at the moment. |
WOODI2 Occasional Visitor
Posted: Sat Aug 26, 2006 12:41 am Post subject: |
I've had the same reply from TrafficMaster
Quote: | It has been brought to my attention that a specific antenna sold with some of the Garmin units does not seem to be performing adequately, this is being investigated presently. In our experience the older antenna the GTM11 seems to perform better.
Posted: Sat Aug 26, 2006 1:31 am Post subject: European Maps |
Can anyone tell me if the Euorpean Maps that are on CD/DVD street level mapping or major roads only? |
Posted: Sat Aug 26, 2006 9:08 am Post subject: |
It's street level mapping on the dvd, major roads are pre-installed on the Nuvi. |
mabsey Occasional Visitor
Posted: Sun Aug 27, 2006 12:52 pm Post subject: |
UPDATE:
We I've had traffic now without problem since my last post over a week ago, but I thought I would run a few more tests and report back.
Test 1 - Using Ciggarette Cable that Came with Garmin
Result : No matter where I put the Arial I go no Traffic at all.
Test 2 - Using a Different USB Adaptor (E13 Model CC0103) and a straight through USB lead.
Test 3 - Using same USB Adaptor above, but with a USB lead that has the round noise suppressor built in.
Result: Traffic everytim within 12 seconds of Turning the Unit on. Also when I go into traffic setting I get the Option for RAC Live and get page upon page of updates.
I ran the above test 3 times each, and got the same result everytime. I think RAC's comment about the arial is probably true and somehow this USB lead with the noise suppresor just does enough to get my traffic.
Mabsey |
Posted: Sun Aug 27, 2006 7:55 pm Post subject: |
Further Update :
Test 4 - Straight Through USB lead connected to Desktop PC
No Traffic
Test 5 - USB lead with Suppresser Ring Fitted
Once again, traffic within 20 seconds and thats from indoors. I went into the secret menu and this is what it said:
TUNED CHANNEL 83
CC 12
SID 7
LEVEL 6
ERROR 7
MODE 2
N SYNC 0
MESSAGE COUNT 38
I went into setting and it had picked up RAC live again and the Message Count above was going up.
If I can get a picture of this usb lead I will post a link.
Mabsey |
RDS Regular Visitor
Posted: Sun Aug 27, 2006 11:38 pm Post subject: |
So it appears that despite the fact that Garmin, Halfords and now Trafficmaster are all saying they are aware of problems with the GTM12 it continues to be retailed on the high st.
Obviously Trafficmaster aren't in anyway liable as they neither manufacture nor sell the unit however both Garmin and, more importantly as your Contract Of Sale is with them, Halfords are.
What is the legal situation in a retailer selling goods which they know aren't 'fit for purpose' ?
Surely the GTM12 should be withdrawn from sale, albeit possibly temporarily, until the intermittent reception problems are finally and totally resolved. |
Posted: Mon Aug 28, 2006 10:35 am Post subject: |
As I said before, here's a couple of pictures of either ends of the cables.
This combination gets my traffic working perfectly.
http://www.tbarecruiter.co.uk/gtm/end1.jpg
http://www.tbarecruiter.co.uk/gtm/end2.jpg
I know this is no help to anyone who's set-up isn't working, but it gives you an idea of what I needed to do to get mine working. With a straight through lead without that round part on the end of the cable, the traffic dont work at all.
Mabsey |
