phoenixbbs Occasional Visitor
Posted: Sat Aug 26, 2006 9:32 pm Post subject: "Linking" to a map location via external app ? |
Not sure whether this could be done (I don't even have a TomTom unit to play with !) but...
I need to know if its possible to construct a link via an external app that feeds a destination into TomTom 5 (in a similar way to a google earth link) on a PDA.
There's a long story behind it, but there's a requirement for the "POI" data to be held in an encrypted form, but I want to be able to use this to set the waypoint / destination directly if possible...
Can anyone give me any pointers - is it possible ?
TIA :-} |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Sat Aug 26, 2006 11:41 pm Post subject: |
Oldboy gave this as a suggestion in a previous thread. Use Autoroute and save as an Itinerary.
Quote: | Do you mean a Program like ITNConv, which can be found here
_________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
lbendlin Pocket GPS Staff
Posted: Sun Aug 27, 2006 3:54 am Post subject: |
you can also use the API calls that are described in the SDK documentation. You don't even need to buy the SDK for that if you are ok with Linux shell scripts. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun Aug 27, 2006 2:28 pm Post subject: |
Thanks for the replies - the only thing is, there are probably 15,000-30,000 (i'm waiting for details, it may not be that bad...) "waypoints" that I could do with being able to search on and navigate to directly - not sure whether that would be possible with an itinery - or whether it would be possible to encrypt the itinery so they're not readily available should the unit be lost...
I'll have a look to see if I can find any API links - they sound like my best bet, i've never having done any programming on a PDA (or used any API calls), so I could be in for some fun :-}
Thanks again ! |
Posted: Sun Aug 27, 2006 10:13 pm Post subject: |
Thanks - the SDK documentation appears to show it does what's needed, so i'll see if they're up for a little coding :-) |
alix776 Pocket GPS Moderator
Posted: Sun Aug 27, 2006 11:07 pm Post subject: |
might not be what your looking for exactly but have you thought of tomtom work
or copilot 6 as these have tracking and messaging features built in and will take the .ov2 format _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Aug 27, 2006 11:36 pm Post subject: |
Its a system that is / has been introduced at work, but they have some major performance issues at present - I have had no input on specification or hardware, and probably don't know enough at that level anyway to do so.
At present, I am lead to believe the *entire* mapset is being encrypted, which I suspect is the cause of the problem (taking time to decrypt), so if I can find a way to seperate and encrypt the POIs - then using standard map data - it might help resolve the problems...
I'm guessing - without having any comparative performance references (which i've suggested doing), removing the processor / memory / memory card bandwidth overhead of decrypting should go a long way towards making it usable. |
