Pocket GPS World :: View topic - Fortuna Bluetooth Clip On, iPAQ4150 and Tom Tom Software
SteveProffitt
PostPosted: Fri Jan 02, 2004 11:31 pm    Post subject: Fortuna Bluetooth Clip On, iPAQ4150 and Tom Tom Software Reply with quote
Question
I have a problem when planning offline without the Bluetooth Connection. The Tom Tom Software when loaded insists on Bluetooth connection, when cancelled it just loops back to trying to get a connection. It is sometimes possible to break out of this loop but this can take a long time or a soft reset may be needed.
Tom Tom have indicated that it is probably a Fortuna Bluetooth problem as all the latest versions of the software have been loaded and this is a problem they are not aware of with other hardware combinations.
When navigating the Fortuna Bluetooth Clip On works fine.
Any advice would be helpful.
Steve Proffitt
PostPosted: Fri Jan 02, 2004 11:52 pm    Post subject: Reply with quote
I have replied in the following thread.
Fletch
PostPosted: Sun Jan 25, 2004 2:37 pm    Post subject: Reply with quote
Steve,
I had exactly the same "loop" problem with tt2 bt unit and software and tt told me that there was a problem with my ipaq bluetooth driver (which they appear to be good at blaming everyone else) and not there software or receiver, i then contacted Hp and after installing the latest drivers still had the same problem.
I have since read many threads on this site which indicate that the fault seams to lie with the tt product and there ver 2.08 and 2.09.
I’m no expert but hope some one with a little more insight can assist you as i know how frustrating it is having a product that doesn’t quite work!.
For me i ditched tt2 i favour of waiting for a more stable version of a gps software to be available.
All the best
Fletch
selwonk
PostPosted: Mon Jan 26, 2004 4:16 pm    Post subject: Connect to Bluetooth first Reply with quote
I had exactly the same user experience. It's not so much of a fault as my understanding of how it was trying to communicate
I found that it is best to ensure that the GPS settings are always switched off. That is to say that you should let TomTom turn on/off the GPS connection when it needs it. As soon as you hit the Navigator panel TomTom will try to connect - so don't go to this panel unless you need to
The other tip (especially on the iPaq 1940) is to use the Bluetooth manager to connect to the GPS device before running TomTom
22.064 (26 Jun 24)
