paulthetool Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_013.gif)
Joined: Nov 21, 2005 Posts: 45 Location: Clacton on sea, Essex
Posted: Thu Aug 24, 2006 8:05 pm Post subject: Installing speed cams ? |
Hi all,
anyone know where I can download the infomation on how to convert
and install the speed cam files? don't seem too easy to me!
Thanks in advance
Paul
paulyoung04@aol.com |
alix776 Pocket GPS Moderator
Posted: Thu Aug 24, 2006 8:40 pm Post subject: |
its on the disc youll need to convert the csv download to to an xls files and then import it in to the poi coverter then name the fmef file created to 999mef then put in the gb folder from memory ill give it a go later and post back _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Thu Aug 24, 2006 9:03 pm Post subject: |
the app you need on the disc is called getmef you can find it by browsing the disc ill have to ring directions in the morning as my disc is playing up
if you also look in the manual for scout warnings the instalation procedure is on there _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Fri Aug 25, 2006 7:59 am Post subject: |
Can't find that on my disk?
I also did a google search with no luck
Paul |
Posted: Fri Aug 25, 2006 10:09 am Post subject: |
Thanks for all the help.
I found ALL the info i needed at
www.directions.ltd.uk
Paul |
