Pocket GPS World :: View topic - Installing speed cams ?
paulthetool
PostPosted: Thu Aug 24, 2006 8:05 pm    Post subject: Installing speed cams ? Reply with quote
Hi all,
anyone know where I can download the infomation on how to convert
and install the speed cam files? don't seem too easy to me!
Thanks in advance
Paul
paulyoung04@aol.com
alix776
PostPosted: Thu Aug 24, 2006 8:40 pm    Post subject: Reply with quote
its on the disc youll need to convert the csv download to to an xls files and then import it in to the poi coverter then name the fmef file created to 999mef then put in the gb folder from memory ill give it a go later and post back
device Lumia 950 xl
alix776
PostPosted: Thu Aug 24, 2006 9:03 pm    Post subject: Reply with quote
the app you need on the disc is called getmef you can find it by browsing the disc ill have to ring directions in the morning as my disc is playing up
if you also look in the manual for scout warnings the instalation procedure is on there
device Lumia 950 xl
paulthetool
PostPosted: Fri Aug 25, 2006 7:59 am    Post subject: Reply with quote
Can't find that on my disk?
I also did a google search with no luck
Paul
paulthetool
PostPosted: Fri Aug 25, 2006 10:09 am    Post subject: Reply with quote
Thanks for all the help.
I found ALL the info i needed at
www.directions.ltd.uk
Paul
22.062 (12 Jun 24)
