Pocket GPS World :: View topic - i3 System Software Missing
dawahar
PostPosted: Tue Aug 22, 2006 6:34 pm    Post subject: i3 System Software Missing Reply with quote
HELP !!!!
Have just tried to update an i3 to version 3.10 using the web updater
at 84% completed the screen suddenly displayed System Software Missing
Can anyone advise on how to correct this ?
Appreciate any advice
RODTROTTER
PostPosted: Tue Aug 22, 2006 7:37 pm    Post subject: Reply with quote
try running the update with out using the web updater ie download the update and run it on your pc
dawahar
PostPosted: Tue Aug 22, 2006 9:09 pm    Post subject: Reply with quote
RODTROTTER
Excuse my ignorance, but how do I run the update when it does not appear to have loaded , Can I download it without the web updater ?
If I can download it what program do I use to run it ?
Is everything stored in the memory card ? if so could I copy data from another i3 then transfer to this card
Thanks for replying
sunstrip_steve
PostPosted: Tue Aug 22, 2006 9:14 pm    Post subject: Reply with quote
You should be able to download the program from Garmin. Then double click to run, and it should install. I had a loading problem once, Garmin told me to always use a motherboard USB port, not a USB hub port on the front of the PC.
Good luck
mk_graham
PostPosted: Tue Aug 22, 2006 9:19 pm    Post subject: Reply with quote
The i3 downloads page is the place to go:
Here
Download the 'Unit Software' executable; double-click and hey-presto (hopefully).
Garmin i3 gone (sold on eBay)
V7 PMD 1400 with Western Europe Maps gone (sold in local paper)
TomTom Go 720 WE Maps (for sale)
iPhone with Sygic Mobile Maps (Europe) - having problems
dawahar
PostPosted: Wed Aug 23, 2006 9:07 am    Post subject: Reply with quote
Downloaded program into PC no problem
transferred into Garmin no problem
But screen now says "Please use the provided PC software to load maps containing turn-by-turn route information.
Any Ideas as the disc that came with the unit I think only had drivers etc.
mk_graham
PostPosted: Wed Aug 23, 2006 9:21 am    Post subject: Reply with quote
Do you have the SD card inserted in the unit?
zogman
PostPosted: Wed Aug 23, 2006 9:52 am    Post subject: Reply with quote
also if the card is in the unit and it still dont work try taking the card out and re-inserting it in a couple of times..
dawahar
PostPosted: Wed Aug 23, 2006 10:35 am    Post subject: Reply with quote
Tried with card in and out still the same request
I now have a 2nd unit which upgraded ok, should I try swapping cards or do I not go there ?
Appreciate all your help
zogman
PostPosted: Wed Aug 23, 2006 10:41 am    Post subject: Reply with quote
change cards ...it wont cause any problems mate..but dont download anything onto the working card..
dawahar
PostPosted: Wed Aug 23, 2006 10:51 am    Post subject: Reply with quote
Tried card from 2nd unit and working OK
What next ? can I copy contents from one to the other ?
thanks again
zogman
PostPosted: Wed Aug 23, 2006 11:05 am    Post subject: Reply with quote
now we know that the card seems to be at fault...as suggested before try and reload the firmware onto the dodgy card..try this a few times ...if this does not work ,you could have somehow messed the card up....if this is the case then a call to garmin should help..
dawahar
PostPosted: Wed Aug 23, 2006 1:32 pm    Post subject: Reply with quote
Spoke to Garmin and they confirm that there appears to be a problem with the card, Sending unit and card back to Garmin.
Thanks for all your help anyway.
zogman
PostPosted: Wed Aug 23, 2006 1:36 pm    Post subject: Reply with quote
if the unit is not to old you might get an exchange from the shop....just a thought..
22.055 (29 May 24)
