Pocket GPS World :: View topic - Internal Navman error on installing August's mobile 30 file
jm202067
PostPosted: Sun Aug 20, 2006 5:06 pm    Post subject: Internal Navman error on installing August's mobile 30 file Reply with quote
I can't install August's mobile 30 limit camera file (speed zoned) on my Navman icn 520.When i try to install it a warning pops up saying 'internal navman error' The rest of the files install ok and i am thinking that there may be a problem with this particular file?
PostPosted: Sun Aug 20, 2006 5:48 pm    Post subject: Reply with quote
Are you sure its the Mobile 30 that is giving problems? I thought this issue was centered around the GATSO 30 camera file please have a read of THIS as it details how to fix the problem (see Tims first post in the linked thread) - Mike
jm202067
PostPosted: Sun Aug 20, 2006 5:55 pm    Post subject: Reply with quote
Yes it is definately the mobile 30 speed zoned file that is causing the error. I installed may's mobile 30 file a while back without problems but have since deleted it from my pc so therefore can't install an earlier version.
jm202067
PostPosted: Sun Aug 20, 2006 7:07 pm    Post subject: Reply with quote
Have just found june's database on my pc and the mobile 30 fine installs fine on my icn 520. For some reason August's shows 'internal Navman error' when trying to install?
jm202067
PostPosted: Sun Aug 20, 2006 7:12 pm    Post subject: Reply with quote
jm202067 wrote:
Have just found june's database on my pc and the mobile 30 fine installs on my icn 520. For some reason August's shows 'internal Navman error' when trying to install?
SafetyEngineer
PostPosted: Tue Aug 22, 2006 8:09 pm    Post subject: Reply with quote
Same here have got a problem, everything bar the mobile 30 loads up, mobile 30 throws up 'internal navman error'.
Regards
Tim Buxton
PostPosted: Wed Aug 23, 2006 10:34 am    Post subject: Reply with quote
This is similar to a problem we had with the last release, but this time it's affecting a different file. The quick fix for this one is to delete Mobile 15138. You can do this in Notepad or from within the Navman POIEditor. Once again, this does not affect devices running SmartST2006 and the mobile site is in the Republic of Ireland so its removal will not affect the integrity of the UK database.
Tim
23.012 (08 Jan 25)
