Pocket GPS World :: View topic - Mio c 710, Guru code hacks
miomio
PostPosted: Mon Aug 21, 2006 3:55 pm    Post subject: Mio c 710, Guru code hacks Reply with quote
Folks
Since 'Palexr' initiated me to the dutch site (& thx. to 'Palexr' for that), I have been going through the forums quiet religiously over there. Since I got all my initial troubles sorted out via this site, the least I can do is to contribute and share some things that are going quiet 'wow' on the dutch site, hopefully that knowledge may assist users here too.
I will be translating all the hacks 1-by-1 and in some period of time.Some hacks may already be known here and some may not be, so if moderator, or admin thinks, I am cluttering up the site,or not following rules ;-) please let me know and I shall stop.
Here's the 1st hack anyway:-
1) where :-"config\default.vis":
remove/comment out by [Label500m-3000m]:
in the place -- POI (from line 358) the line for petrolstations and
add in [Label0m-4300m] & in [Label4300m-30km]:
Code:
poi="Services.Petrol_Station", "", "label_poi", 9,"poi2",-1
effect:-The above hack will show petrol stations visible from 0 meters to 30 KM instead of the usual 500 meter & 3 KM and there will always be an icon of the petrol station instead of a boring blue dot which may be missed if not really focussed upon.
2) one may replace the default 'audio\!alert5.wav' with something more soothing [ for camera alerts ]
3) in ui_mio\func_tracking_320_240.ui
comment out line 16.
effect:- in advanced settings , the hidden button "route option" will be no longer hidden.
I personally haven't tried these & wouldn't recommend to anyone, so it's all upto you at the end.
as mentioned, if this is not with the rules of this forum, just one line would be enough.
HTH
Simebaby
PostPosted: Mon Aug 21, 2006 5:10 pm    Post subject: Reply with quote
That's very helpful - I look forward to more of the same! :D
miomio
PostPosted: Fri Aug 25, 2006 3:52 pm    Post subject: Reply with quote
as promised, here I was with more , but after writing all that stuff, It keeps throwing up :-
"The html tags you attempted to use are not allowed
[ Go Back ]"
this was an excercise in frustration, and in my opinion, this security feature is more detrimental than supportive.
or at least it should show(parse) the lines, where it thinks it has gone wrong.
anyway , if anyone's interested in rest of the hack codes:-
pl. mail me at :-
erg_handig@mail.com
and then someone can cleverly put it all back here without me trying to find out what went wrong in 297 lines of text I wrote Rolling Eyes
linknet
PostPosted: Sat Aug 26, 2006 12:01 am    Post subject: Reply with quote
Hi MioMio
Thanks for the email. The problems with posting this are the left and right angle brackets (lesser than and greater than symbols).
The only way is to replace them with another set of brackets and include a note similar to this:
(NB '{' should be a left angle bracket and '}' should be a right angle bracket)
Regards
Roger
miomio
PostPosted: Mon Aug 28, 2006 7:52 am    Post subject: Reply with quote
I don't think it's as easy as mentioned.
there were others who tried and failed.
and including one of such mails I rec'd.
Thanks for the hacks.
Tried to post them to the forum but, like you, got the error message
about HTML tags even when disabling HTML on the post. Have you no web
space that you can put it on then people could access the information
directly?
Reg
so here's a poor man's workaround:-
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=59568&whichpage=12
** PS:- if other sites are accepting this without complaining, dunno what's biting this forum site ?
miomio
PostPosted: Tue Aug 29, 2006 2:44 pm    Post subject: Reply with quote
There's some more come in @ the same place.
& this one's about :-
there is this option in the Igo manual "calculation algorithm" {Fast & Optimal}. This is in the chapter 5.4.1 , 'Igo manual'.
This function will influence the speed & sensitivity during all route calculations.[ under settings / "route" , one can now make use of this new algorithm ]
miomio
PostPosted: Thu Aug 31, 2006 1:54 pm    Post subject: Reply with quote
& on
http://www.gpspassion.com/upload/DATA.ZIP
you can find this hacked-up file.
This should save you all the exasperation.(something, I surely went through ,during all those hack sessions ) Rolling Eyes
enjoy the c710 in it's naked glory Burn In Hell
rronaldson
PostPosted: Thu Aug 31, 2006 2:23 pm    Post subject: Reply with quote
doesn't work on my 510E. After the Miomap loading screen it just resets the device.
Reg
miomio
PostPosted: Thu Aug 31, 2006 7:18 pm    Post subject: Reply with quote
sorry pal, maybe then its only 710 specific.
It's up & running on my 710, so I can vouch for that & I'm pretty sure it will be up & running on other 710s too.
rronaldson
PostPosted: Thu Aug 31, 2006 8:02 pm    Post subject: Reply with quote
Hmm .... you could be right. Shame if it won't work on the 510.
I might try applying the changes one function at a time if that's possible.
Reg
miomio
PostPosted: Thu Aug 31, 2006 8:12 pm    Post subject: Reply with quote
G'Luck Reg !
sorry , couldn't help you here Crying or Very sad
rronaldson
PostPosted: Thu Aug 31, 2006 9:45 pm    Post subject: Reply with quote
miomio wrote:
G'Luck Reg !
Thanks miomio. I will need it Smile
Right ................ I've coded in the changes for Advanced Settings/Cockpit Settings. I've compared my new file with the one you supplied and they look the same but .............. on the Cockpit Settings page the sliders for Fields A, B and C of Cockpit Screen Layout are overwriting the new check boxes. The Cockpit Screen Layout is at the bottom of the page with no sliders.
Reg
rronaldson
PostPosted: Thu Aug 31, 2006 11:53 pm    Post subject: Reply with quote
Miomio,
I've got the Advanced Cockpit Settings working now.
I hope you don't mind me asking but are you sure that the copy of DATA.ZIP that you have made available is the working version?
Reg
rronaldson
PostPosted: Fri Sep 01, 2006 10:37 am    Post subject: Reply with quote
Miomio,
Can't get Advanced Route Options to work. Actually I can't find this option on my 510. Is this a 710 thing only? Oddly enough the code is there but altering it is giving me an error on loading.
Oh well, it's interesting to find out how this code works if nothing else :D
Reg
rronaldson
PostPosted: Sat Sep 02, 2006 3:37 pm    Post subject: Reply with quote
I've now managed to get all of miomio's hacks working on my 510e (Miomap 3.0).
Reg
22.094 (25 Sep 24)
