Pocket GPS World :: View topic - Error when converting csv to gpx
LESLIEAD
PostPosted: Fri Aug 18, 2006 1:00 pm    Post subject: Error when converting csv to gpx Reply with quote
PocketGPSWorld.com Speed Camera Database Version 4.075 17 August 2006 I am getting an error when converting csv file for uk mobile to gpx it shows popup type mismatch.
Any Ideas on correcting this
Kind Regards
Leslie
missing_user
PostPosted: Fri Aug 18, 2006 1:57 pm    Post subject: Reply with quote
Why are you converting to .gpx when the downloaded database has them as .gpx anyway?
swing
PostPosted: Fri Aug 18, 2006 2:16 pm    Post subject: Re: Error when converting csv to gpx Reply with quote
Yes, there's a problem with the data. Open the Mobile CSV file, and scroll do to the following Mobile cameras:
22205
22206
22208
22212
22468
On each the 3rd value is wrong: it says things like MOBILE:22205@54.5995 - remove the '@' and everything afterwards, and the file will then work.
What's happened is it looks like a copy'n'paste error in that instead of the speed being listed, the latitude (from the 2nd value) is there instead, and the convertor can't cope with it.
Unfortunately, these are all new cameras this month, so there's no equivalent entry from last month to provide the correct speed for these cameras.
BoneMan1946
PostPosted: Fri Aug 18, 2006 2:16 pm    Post subject: Reply with quote
To add the special features via Ash10's software Wink ?
LESLIEAD
PostPosted: Fri Aug 18, 2006 3:35 pm    Post subject: Reply with quote
Thanks swing
Regards
Leslie
welshgasman
PostPosted: Mon Aug 21, 2006 8:29 pm    Post subject: Reply with quote
Nice one Swing.
I had the same problem.
Perhaps it could be tested before the files are released.???
The other month I had a similiar problem with a download.
I *thought* that the gpx files took up less space.?
Am I wrong in this?, which is why I was using it.
TIA
22.064 (26 Jun 24)
