Pocket GPS World :: View topic - Rider and contacts txt
mick-b
PostPosted: Wed Aug 09, 2006 8:07 pm    Post subject: Rider and contacts txt Reply with quote
Had the rider for a while and used the work around to get my phone numbers into the rider.
my nokia 6680 isn't compatable so i had to create a text file.
this worked fine till i ran tom tom home and it told me version 6.15 was available.
big mistake now the contacts.txt trick does not work
anybody know what the format is now ?
robbarron1
PostPosted: Tue Aug 15, 2006 2:37 pm    Post subject: Reply with quote
Ooooh! What is the Contacts.txt trick?! Had a quick search but couldn't see anything Question
mick-b
PostPosted: Wed Aug 16, 2006 12:04 pm    Post subject: Reply with quote
easy you create a text file named contacts.txt
and insert names and numbers in this format
"name","12345"
then place the text file in the root directory of your tom tom.
trouble is it doesn't work with version 6.15
mick-b
PostPosted: Wed Aug 16, 2006 12:52 pm    Post subject: Reply with quote
update create the text file as per usual then create a folder in the root directory name it contacts and put the text file in there and you have your phone book back
chapo
PostPosted: Thu Aug 17, 2006 11:25 pm    Post subject: contacts Reply with quote
Have tried your workaround for phonebook, i cannot get it to work, phonebook still greyed out.
any advice would be helpfull
cheers.
chapo.
sgould
PostPosted: Thu Aug 17, 2006 11:49 pm    Post subject: Reply with quote
In moving the file around has it been renamed contacts.txt.txt?
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
PostPosted: Fri Aug 18, 2006 7:15 am    Post subject: Reply with quote
See Here for V6.150 contacts location.
chapo
PostPosted: Fri Aug 18, 2006 7:44 pm    Post subject: contacts Reply with quote
Hi All,
thanks for info, seems i saved the txt file contacts.txt which made it contacts.txt.txt now sorted.
thanks again.
chapo.
