booboo2006 Occasional Visitor
Posted: Sun Aug 13, 2006 4:28 pm Post subject: Help!!!! with installing the speed camera software on my PDA |
I a PDA with Tom Tom Nav 5 software I have followed the instructions but it don't work!!!!!
Please can someone help me by phoning me on:
01443 673067
07717 505434
07813 125673
I will phone you straight back
Regards
Lee |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Sun Aug 13, 2006 8:27 pm Post subject: Re: Help!!!! with installing the speed camera software on my |
booboo2006 wrote: | I a PDA with Tom Tom Nav 5 software I have followed the instructions but it don't work!!!!! | Which Speed Camera Software are you referring to? POICapture or Speed Camera Database? _________________ Richard
Posted: Sun Aug 13, 2006 8:38 pm Post subject: |
POI
Lee |
Posted: Sun Aug 13, 2006 8:49 pm Post subject: |
Have you downloaded the correct Version for your Operating System?
There are 2 flavours for PDA, as shown here.
Did you follow these instructions.
Quote: |
Installation
Prior to installing please check that you are running the correct version of TomTom Navigator.
The steps to a successful installation are:
1. Download the POICapture.CAB file and save it on a folder on your PC.
2. Copy the POICapture.CAB file to the root of your storage card.
3. Use the PocketPC File Explorer to run the POICapture.CAB file
The POICapture.CAB file will create the following folders, if the folders do not already exist:
* My Pocket PC\TomTom\SdkRegistry My Pocket PC\Program Files\POICapture |
phirana Occasional Visitor
Posted: Thu Aug 17, 2006 1:04 am Post subject: adding POI |
Dont know whether this helps - i found all the above not really useful so i decided to play around with navigator 5.
1) Backed up tomtom SD to pc
2) Down loaded database
3) Copied database to storage care\Great_Britain-Map\
(pocketgps_uk_sc.ov2 and pocketgps_uk_sc.bmp)
4) Restarted tomtom
5) Change preferences | Manage POI | Add POI | and selected pocketgps uk sc
And it now works
Hope this helps |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Thu Aug 17, 2006 8:07 am Post subject: |
Phirana, I would also go to Change Preferences/ Manage POI/ Warn When Near POI and set this up so you get a warning of the approaching camera - Mike |
Posted: Wed Aug 23, 2006 10:26 pm Post subject: Of course |
Sorry,
I figured that out after I posted ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
cadey Occasional Visitor
Posted: Sat Aug 26, 2006 12:44 pm Post subject: speed camers audio alerts |
hi guy's and girls new to all of this just downloaded the camera database to my pda running tomtom5 whilst driving when comeing up to a speed camera i get the pic of a camera on route but no audio alert is this right or am i doing something wrong please help. thanks |
meggles Occasional Visitor
Posted: Thu Sep 07, 2006 7:19 pm Post subject: can't view camera POI on Tomtom |
i've downloaded the files, unzipped them, copied both the .bmp & .osv to the folder which contains the Great Britian Map.
I've done a soft restart of my ipaq.
when i open TomTom, Change Preferences, Manage POI, Enable/Disable POI, I just see the usual list of airport, beaches, etc. i don't see any speed camera options.
what am i missing here in the installation process? thanks in advance. |
Posted: Thu Sep 07, 2006 7:22 pm Post subject: |
Are you sure you have put the correct down load on to your device? as it is a TomTom unit you need the BMP and ov2 files, please check what the file extension is that you have loaded - Mike |
Posted: Thu Sep 07, 2006 7:24 pm Post subject: |
i've dowloaded the bmp & ov2 files. all in all there are 8 files. |
Posted: Thu Sep 07, 2006 7:30 pm Post subject: |
Go to Change Preferences/ Manage POI/ Warn when near POI and see if they are listed in here?
There is a limit of 39 Custom POIs on TomTom vs5 and 100 if using a Go device running vs6, if you have loaded any other POI's and exceeded the limit this may explain the fact the POI's are on the card but you cannot see them in the application.
If you are not too sure what custom POI's are on the device, look at the card through file explorer and count how many files have the ov2 file extension - Mike |
Posted: Thu Sep 07, 2006 7:34 pm Post subject: |
good suggestion - but already tried looking in POI warnings. not their either.
i haven't downloaded any other POI onto this ipaq pocket pc. in fact when i go to manage POI only three of the six options are in color. i don't have the ability to clink on "add POI", "Delete POI", "Delete POI Category".
i've also tried deleting all these files and then reinstalling them from scratch. |
Posted: Thu Sep 07, 2006 7:37 pm Post subject: |
Try downloading the file again, then unzip the download placing the files into the map folder on the device, if you are using the consolodated by type installation you should have 5 bmp files, 5 ov2 files, 2 txt files and a htm file. Only copy the ov2 and bmp files to your card. - Mike |
Posted: Fri Sep 08, 2006 9:45 am Post subject: |
thanks for your patience. i was saving them to a file on the "hard drive" of the pocket pc, rather than the storage card. all done!!! yippee!!! question-how many yards does everyone set their warnings for? is 300 yards enough? |
