ploppy15 Occasional Visitor
Posted: Wed Aug 16, 2006 5:38 pm Post subject: Demo mode TTNav5 |
Hi. thx for i9nformative forum. only got unit today so i need a bit of guidance if poss. specs are:
Acer n35
TomTom navigator
App Version 5.210 (5430)
Free Ram: 13.7MB
GPS Driver v1.20
Map: Great_Britain-Map v605
Language: English UK
I downloaded the file pgpsw-speed-cams.zip which contained Version 4.074
22 July 2006. I followed the instructions and installed the files as stated. My question is, do the cameras etc show in demo mode on the map or do u have to be driving? Thx 4 help. |
JockTamsonsBairn Lifetime Member
![](modules/Forums/images/avatars/202069601647f4a51ae4e4d.jpg)
Posted: Wed Aug 16, 2006 6:02 pm Post subject: Re: Demo mode TTNav5 |
ploppy15 wrote: | My question is, do the cameras etc show in demo mode on the map or do u have to be driving? Thx 4 help. | They show up on the demo. You don't get the warnings if you run the demo over 400%. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Wed Aug 16, 2006 6:56 pm Post subject: |
Make sure you have configured the warnings or you will see nothing in either Demo mode or when driving. go to Change Preferences/ Manage POI/ Warn when near POI and configure each camera type you have loaded, if its the single file type you only have one to worry about, consolodated by type contains five and the Speed zoned set-up required 24 camera alerts to be set-up (well worth the extra effort) - Mike |
Posted: Wed Aug 16, 2006 11:02 pm Post subject: |
thx 4 reply guys. however, i cannot see either cameras or traffic lights in either demo mode or driving. Do i need to delete the default files before i added the new single file type. all entries are ticked and active. thx |
Posted: Thu Aug 17, 2006 1:34 am Post subject: |
ploppy15 wrote: | thx 4 reply guys. however, i cannot see either cameras or traffic lights in either demo mode or driving. Do i need to delete the default files before i added the new single file type. all entries are ticked and active. thx | What default files? If you mean the TT built in POI files, no you can't remove them.
There is a limit to the number of POI files that you can have (39, I think), but if you're using the SingleFile database, you shouldn't run into problems, unless you've gone mad with Little Chefs & Esso Stations :D _________________ Jock
Posted: Thu Aug 17, 2006 2:06 pm Post subject: |
Thx bgf 4 reply. I have not made myself very clear. I am totally new to this and only had the unit 48 hrs so still learning :-). Here r the contents of the folder on the SD / MMC card. Code: | E:\Great_Britain-Map | . Code: | Cdlabel.alb
Great_Britain-Map.cfg
cline.dat
cname.dat
cnode.dat
faces.dat
mapinfo.dat
poi.dat
tmccodes.dat
traffic.dat
traffic.inc
Great_Britain-2458b013.mac
Great_Britain.mid
pocketgps_uk_gatso.ov2
pocketgps_uk_mobile.ov2
pocketgps_uk_redlight.ov2
pocketgps_uk_specs.ov2
pocketgps_uk_temp.ov2
Great_Britain.pna | I then have file Code: | TomTom_Speed_Cameras_Database_For_Great_Britain__July_2006.zip |
which i downloaded from here. 1) do i need to remove the other ov2 & bmp files in this directory or do i just add the contents of zip file? I have enabled in POI with warnings, bell etc but still nothing appears on route. any other POI i enable ie cinema etc shows. I only have the camera POI's enabled so the 39 POI thing isn't an issue. Obviously, i am missing something very basic here, so any guidance would be greatfully received. Thx. |
peterc10 Frequent Visitor
Posted: Thu Aug 17, 2006 3:11 pm Post subject: |
Yes you are missing something - reading the posts!
As Mike has already said you need to tell TT to warn you when you approach these otherwise you will get nothing. Follow the instructions in his post and let us know how you get on. _________________ Peter
HTC Sensation
Copilot for USA
Posted: Thu Aug 17, 2006 3:26 pm Post subject: |
peterc, Quote: | I have enabled in POI with warnings, bell etc but still nothing appears on route | from previous post. I have read various other posts trying to find an answer to this problem before i decided to post. also, when mike stated Quote: | Make sure you have configured the warnings | this comes back to earlier reply. I enabled the POI's, then selected ' warn when near PPOI' selected 500 yards then selected bell then enabled select only if POI is on route. Is that correct? because nothing is appearing. Please bear in mind i am a complete neewb when it comes to this. However, if this is the wrong forum for asking this type of question, please accept my apologies. thx. |
Border_Collie Pocket GPS Verifier
![](modules/Forums/images/avatars/846718549526d5fd14b726.jpg)
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Thu Aug 17, 2006 6:49 pm Post subject: |
I have to ask, just in case.
Did you unzip the files first and copy the files from the new unzipped folder to your GB_Folder, or copy them straight from the .zip folder? _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Thu Aug 17, 2006 6:53 pm Post subject: |
I unzipped them first then copied to folder. thx |
Posted: Thu Aug 17, 2006 7:05 pm Post subject: |
As the files are on the card all you need to do is set-up the "Warn When Near POI" which is found in Change Preferences/ Manage POI you need to set-up all five files seperately.
When you have chosen a demo route have you actually made it go past a camera location.
When driving with the device you need to have a route planned to get a warning as you have selected "Warn if POI on route" if you have no route planned then the unit cannot generate a warning, don't worry about asking questions - we all had to start from somewhere - Mike |
Posted: Thu Aug 17, 2006 7:19 pm Post subject: |
thx 4 reply mike. have tried both ways but still no joy. do i need to install again and remove all the ov2 & bmp files from the folder and just insert the files Code: | pocketgps_uk_sc.ov2 & pocketgps_uk_sc.bmp ? | Thx 4 help. |
Posted: Sat Aug 19, 2006 3:31 am Post subject: |
ploppy15 wrote: | thx 4 reply mike. have tried both ways but still no joy. do i need to install again and remove all the ov2 & bmp files from the folder and just insert the files Code: | pocketgps_uk_sc.ov2 & pocketgps_uk_sc.bmp ? | Thx 4 help. | That would simplify matters!
Remove:
Add:
pocketgps_uk_sc.ov2
Then, within the application, Change Preferences - Manage POI - Enable POI - find pocketgps_uk_sc & tick the box -- This causes the POI to be displayed on the map.
Then, within the application, Change Preferences - Manage POI - Warn when near POI - find pocketgps_uk_sc & tap it - Enter the Warning Distance - Select the sound - Ensure that the Warn when near is NOT selected -- This causes you to get the warning as you approach the POI.
Let us know how you get on. _________________ Jock
Posted: Tue Aug 22, 2006 1:38 am Post subject: |
thx 4 that BGF. from my specs, what version of the voices software do i need to download? and install help? thx in advance |
Posted: Thu Aug 24, 2006 1:49 am Post subject: |
ploppy15 wrote: | thx 4 that BGF. from my specs, what version of the voices software do i need to download? and install help? thx in advance | Info on this page should help you out. _________________ Jock
