Pocket GPS World :: View topic - Failing Newbie
Failing Newbie
adrianjohn
PostPosted: Tue Aug 15, 2006 6:36 pm    Post subject: Failing Newbie Reply with quote
Like Tonkies, I'm a novice here. I downloaded the zip files following the instructions written by Mike Barrett. When I opened them, I couldn't see a file *garmin* and the data file was ascii. not .csv. I also didn't see anything pointing me to look up the version number. I tried saving what I had downloaded to a new folder, but this wasn't recognised - probably because I didn't have .csv.
What next? Can some kind person out there take me through it in simple steps?!
TIA. adrianjohn
Anita
PostPosted: Tue Aug 15, 2006 7:00 pm    Post subject: Reply with quote
You don't need to open any files - just unzip them, then use POILoader to upload them.
Have you tried the instructions here: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=28985&start=75
Depending on which i3 you have it may say the card is full, in which case you'll need to use a card reader and upload via that instead of the device. See this thread: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=245440#245440
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
adrianjohn
PostPosted: Tue Aug 15, 2006 7:23 pm    Post subject: Reply with quote
Thanks for this, Anita. I managed to unzip files but got the *no space* message when I tried to load them - although I haven't loaded any extras in before.
So I suppose it's a card. It's all foreign to me. Where do I start on that course?
Adrian
Anita
PostPosted: Tue Aug 15, 2006 9:39 pm    Post subject: Reply with quote
There's a card slot in the right-hand side of the i3. If there's a card in there press on it and it will pop out far enough for you to grip it and pull it out. If there isn't a card in there you will need to buy a MicroSD card, also known as a TransFlash card. A Google search will return many online suppliers, eg you can get a 512MB card for £16.95 including adapter so it can be used in any card reader that takes ordinary SD cards here: http://www.mobilefun.co.uk/product/7294.htm. But you may find something cheaper if you look around, and 256MB is probably enough.
Follow the instructions for installing the cameras here: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=28985&start=75, but instead of the i3 connect the card reader with the card inserted and, in POILoader, select the card in the drop down list under 'Device'.
Hope that helps! Smile
Anita
UK map 1130.12368
Samsung Galaxy S21
adrianjohn
PostPosted: Tue Aug 15, 2006 10:28 pm    Post subject: Reply with quote
Thanks again. Your advice is appreciated. Smile
adrianjohn
22.094 (25 Sep 24)
