markyhedgehog73 Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_sp_020.jpg)
Joined: Jun 03, 2005 Posts: 95 Location: East Yorkshire
Posted: Tue Aug 15, 2006 12:16 am Post subject: speed camera alerts |
hi guys,
have tried searching the forum but all it came up with is a vague quote about two files, one saying gatso 1, and the other saying gatso 2 to achieve two warnings before a speed camera, i downloaded the latest database and kept them as they are, then copied and pasted them to the the pc, and renamed each ov2 and bmp file so they did not have the same name as the originals, when i copied them back to the map folder they went on fine and didnt get the overwrite dialog box, but when it came to setting them up in tt5 it just showed the original ones which ive already programmed to alert me at various distances what am i doing wrong
if someone could post a detailed summary of how to achieve the warn at say 600yrds then again at say 200yrds for the same camera i would be most grateful
tia mark |
bedbug Frequent Visitor
Joined: May 10, 2006 Posts: 484 Location: Hampshire, UK
Posted: Tue Aug 15, 2006 12:29 am Post subject: |
You're not running out of POI capacity are you? I think there's a limit of about 47 individual POI files - but someone here will know the exact quantity. _________________ iPhone 4/4S (iOS 5.1.1); TomTom Western Europe (1.10)/USA & Canada (1.10); CoPilot for iPhone (8), UK mapping, Mac OS 10.8/XP Pro/Win7; Tongue firmly in cheek! |
Posted: Tue Aug 15, 2006 12:53 am Post subject: |
thanks bedbug that would account for it then as i am using the individual speed cam files instead of the all in one file.
i'll keep it as it is then shame my registered copy of poi warner doesnt work on my pda with tt
thanks mate |
JockTamsonsBairn Lifetime Member
![](modules/Forums/images/avatars/202069601647f4a51ae4e4d.jpg)
Posted: Tue Aug 15, 2006 1:35 am Post subject: |
markyhedgehog73 wrote: | thanks bedbug that would account for it then as i am using the individual speed cam files instead of the all in one file.
thanks mate | You could add the SingleFile at the cost of only one additional POI & get an extra warning for every camera. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Tue Aug 15, 2006 6:56 am Post subject: |
thing is bfg i have altered the data.chk and tt.exe file to give me the actual speed check of each camera, which i like, not to worry though thanks for the input though matey
all said and done though i may alter the poi file within tt will do ome searching on how to alter that! :D
many thanks |
Posted: Tue Aug 15, 2006 8:48 am Post subject: |
Mark, I have been running with double warnings on my unit for some time, download and install the SpeedZoned set-up, configure this for the 600 Yards warning (I use figures based on time, which you can convert to yards - 1027 Yards = 30 Seconds @ 70MPH).
The download and install the Speed Camera database "consolidated by type", You will need to re-name the following files:
pocketgps_uk_redlight.ov2
pocketgps_uk_temp.ov2
I simply change them by adding _1 to the end of the file name so:
Install these files and configure them for the 200 Yard alert, if you have used POIExtend there are sufficiant warnings to cater for this type of install - Mike |
Posted: Tue Aug 15, 2006 8:05 pm Post subject: |
thanks for that post Mike, what an excellent simple solution i've been racking my brains with checkpoint and poi warner, none of which work on my pda with tt
thanks ever so much you're a gud un :D |
