Pocket GPS World :: View topic - Scan Disk and Defrag on PDA and SD Card
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
tanda
PostPosted: Sun Aug 13, 2006 4:43 pm    Post subject: Scan Disk and Defrag on PDA and SD Card Reply with quote
Hi Everyone, Bit of advice please. If I connect my PDA to my PC, then click on "My Computer", If I call up the properties for the PDA, from there, can i do a Scan Disk and Defrag of my PDA and SD card, Is it a good idea to do it, if so how often, is there another program I should use. Is defraging/scan disk a good idea on memory cards in general, the one in my camera, Play station portable? Thanks in advance for any help.
Audi A3 Sline sat nav
Oldboy
PostPosted: Sun Aug 13, 2006 8:34 pm    Post subject: Re: Scan Disk and Defrag on PDA and SD Card Reply with quote
It is not a good policy to use Defrag on a Memory Card, because of the limited number of Read/Write cycles that it has. Although this may be in the millions, a Defrag can thrash a Card.
Much better to Copy the Card Contents to PC, Reformat the Card then Restore the Copied Files back to the Card. Probably quicker as well.
Mullet
PostPosted: Mon Aug 14, 2006 12:23 am    Post subject: Reply with quote
The main benefit of defrag is to reduce seek times across a drive. While significant performance gains can be achieved on a mechanical hard disk (platter and armature), the gains are far less noticeable on a relatively low capacity solid state storage card.
Oldboy
PostPosted: Mon Aug 14, 2006 7:44 am    Post subject: Reply with quote
If you do a Format, and then Restore the Files, this will also be doing the same as a Defrag, but with fewer Read/Writes.;)
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.063 (19 Jun 24)
