Roblatus Occasional Visitor
Posted: Thu Aug 10, 2006 5:53 pm Post subject: Updating Maps on c320 |
Can anyone help me out on how to do this.
My c320 came originaly with City Select v7 maps and i now want to put the City Nvaigator V8 maps on.
I have got the City Navigator v8 update disk but i am having a nightmare trying to update the maps on the unit.
Thanks for any help |
Ericd Lifetime Member
Joined: Dec 23, 2005 Posts: 57 Location: Plymouth Area
Posted: Thu Aug 10, 2006 7:47 pm Post subject: |
Hello Roblatus,
Download the City Navigator Disc to your computer. When done unlock the disc by using the Unlock Code which should be either with the software or sent to you by E mail if the City Navigator Disc was sent to you as an update for your unit, both come from Garmin direct. When done open up the Mapsource Folder read the howto files and you should be able to follow on from there. Ensure your C320 is plugged in and switched on but not until after you have got the disc contents onto your computer.
Hope this helps.
Ericd |
Posted: Thu Aug 10, 2006 7:52 pm Post subject: |
Almost forgot, when selecting the maps from Mapsource ensure you use the Maptool located on the Mapsource Tool Bar,
Ericd |
Posted: Thu Aug 10, 2006 8:17 pm Post subject: |
So far what i have done is as follows
Got my original City Select v7 disks installed to my pc.
Try to install my City Navigator Europe v8 disk but it says during installation that it cannot find a previous version so cancels the install
I browsed the disk and managed to get it to install by selecting the setup file manually.
However when i run the Mapsource program and try to send the maps i want to my unit i get a message saying they are not unlocked.
I have got an unlock code from Garmin and it is listed on MyGarmin along with my City Select v7 information but i cannot get it to work
Am i doing something wrong???
Posted: Fri Aug 11, 2006 5:05 pm Post subject: |
Are you using the Map Unlock Wizard. Go to Start, All programs, Garmin, Unlock Wizard and follow the screens through. If you are already doing this then I suggest you contact Garmin direct at http://www.garmin.com/support/ . They have a good FAQ section and you can also E Mail them Direct. I have done so previously and had a good response even if I have had to wait a couple of days.
Sorry I did not get back to you sooner.
Ericd |
