OzSpider Occasional Visitor
Posted: Fri Aug 11, 2006 12:47 pm Post subject: Best place to locate external antenna? |
I've purchased an external antenna from Maplin (the £9.99 one that everyone on this forum seems to suggest). Where's the best place in the car to locate it?
The reason I purchased the antenna is simply that my new i3 (with firmware 2.7 installed by me) seems to lose the satellites a bit too often, and I'm hoping the antenna will help. I don't have a tinted windscreen or any of the traditional reasons why an external antenna is required. |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Fri Aug 11, 2006 1:01 pm Post subject: |
its been suggested that the right hand side on the vehicle is the best due to the fact that the antenna is furthest away from any buildings on your left....placed outside or on the dash is your preference, both should work well ...experiment first and see.. _________________ *************************** |
portman Frequent Visitor
Posted: Fri Aug 11, 2006 1:24 pm Post subject: |
You can stick it to the roof 'cos its magnetic, feed the cable up behind the door seal or the sunroof surround. |
Posted: Tue Aug 15, 2006 11:42 am Post subject: |
I ended up putting it on the dash (held in place by blue-tak), and that seems to work well enough for me. It doesn't look great - there's a bundle of rolled up cable sitting there (the external antenna comes with a 5m cable), but it works well enough.
Thanks to those who replied. |
JohnGray Regular Visitor
![](modules/Forums/images/avatars/1508796904401ef06a7162.jpg)
Posted: Tue Aug 15, 2006 8:46 pm Post subject: |
It would be a good idea to remove the antenna each time you take the i3 out of the car when parked, otherwise some friendly character may break a window to try to find the i3 which may be hiding in the glove compartment...
A bit of a pain, really.
John |
Posted: Tue Aug 15, 2006 10:32 pm Post subject: |
JohnGray wrote: | It would be a good idea to remove the antenna each time you take the i3 out of the car when parked, otherwise some friendly character may break a window to try to find the i3 which may be hiding in the glove compartment... |
Gosh! How did you know that's what I do with the i3 (grin) |
Posted: Wed Aug 16, 2006 7:40 pm Post subject: |
Just psychic, me...
John |
