colin_thames Regular Visitor
Posted: Wed Aug 09, 2006 2:32 pm Post subject: Version 6.15 used on older TomTom Go's |
Just installed version 6.15 on my TomTom Go 700 and it seems to work well including new feature of Pin code protection... at last! Though this has to be set via TomTom Home on the PC. It may be my imagination, but the sensitivity seems to be better and the TomTom picks up 6 satellites from a foot inside my office window so I can plan a route from indoors.
The only annoying things spotted so far are that if I set it to sync the time, it doesn't allow for BST hour changes, ie my computer shows 13.40 but the clock on the TomTom shifts to 14.40. You have to set it manually.
Also the background to the menus has changed to a light blue. This means POI capture icons look strange (white backgrond). Having said that, I could never get POI capture to work with version 5.44 (?) so I've had to remove it. I wonder now when POI capture will be created to run with version 6.15? |
gadget_sa Frequent Visitor
Joined: Dec 02, 2005 Posts: 334 Location: Wiltshire, UK
Posted: Wed Aug 09, 2006 4:07 pm Post subject: |
colin_thames wrote: | Just installed version 6.15 on my TomTom Go 700 and it seems to work well including new feature of Pin code protection... at last! Though this has to be set via TomTom Home on the PC. It may be my imagination, but the sensitivity seems to be better and the TomTom picks up 6 satellites from a foot inside my office window so I can plan a route from indoors. |
Couldn't agree more, the fix is (seems) far better!
colin_thames wrote: | The only annoying things spotted so far are that if I set it to sync the time, it doesn't allow for BST hour changes, ie my computer shows 13.40 but the clock on the TomTom shifts to 14.40. You have to set it manually. |
I haven't noticed this, but I will check to see if it's doing the same....
colin_thames wrote: | Also the background to the menus has changed to a light blue. This means POI capture icons look strange (white backgrond). Having said that, I could never get POI capture to work with version 5.44 (?) so I've had to remove it. I wonder now when POI capture will be created to run with version 6.15? |
Again, I haven't actually noticed the difference on the icons... weren't they white before??
POI Capture does work on 6.15... well it does on mine! _________________ Steve
iPhone 6 with Western Europe & CamerAlert |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Wed Aug 09, 2006 7:31 pm Post subject: Re: Version 6.15 used on older TomTom Go's |
colin_thames wrote: | I wonder now when POI capture will be created to run with version 6.15? | You need POICapture V1.06G for TT V6.15 _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Thu Aug 10, 2006 1:32 pm Post subject: TTGo v6.15 |
Quote: | You need POICapture V1.06G for TT V6.15 |
Where can I find this OldBoy?
gadget_sa
My mistake, the time seems to show wrong on the TomTomHome window on which you can go through the TomTom menus, plan routes etc when I connected my 700, but on the TomTom itself the time showed fine.
Cheers |
TonyHoyle Regular Visitor
Posted: Thu Aug 10, 2006 1:49 pm Post subject: Re: Version 6.15 used on older TomTom Go's |
colin_thames wrote: | It may be my imagination, but the sensitivity seems to be better and the TomTom picks up 6 satellites from a foot inside my office window so I can plan a route from indoors.
Is this while docked through HOME? The emulator on HOME fakes satellite reception so it always looks like you've got a 100% lock on 6 satellites, even though you may have no lock at all. |
Posted: Thu Aug 10, 2006 2:03 pm Post subject: |
Tony, that's a shock, though thinking about it, it makes sense! What on earth is the point of faking satellite reception? |
Posted: Thu Aug 10, 2006 2:24 pm Post subject: |
Sorry OldBoy, I've just found out that the version of POICapture for the TomTom Go 5.44 is version V1.06G. The only way I seem to be able to find this was by downloading it, then the Save As dialogue showed the file name.
I'd like to give it a go, but won't the .mnu file be wrong now? TomTom firmware 6.15 has introduced some new menu options. Won't they be missing? |
Posted: Thu Aug 10, 2006 4:27 pm Post subject: Re: TTGo v6.15 |
colin_thames wrote: | Quote: | You need POICapture V1.06G for TT V6.15 |
gadget_sa
Cheers |
No worries Colin, I'll try and check it out on mine (a) when I get time and (b) if my brain remembers!! _________________ Steve
Posted: Thu Aug 10, 2006 4:28 pm Post subject: Re: Version 6.15 used on older TomTom Go's |
TonyHoyle wrote: | colin_thames wrote: | It may be my imagination, but the sensitivity seems to be better and the TomTom picks up 6 satellites from a foot inside my office window so I can plan a route from indoors.
Don't know about Colin's but when I'm sat at the PC station I am getting a minimum of 3 sats, (not connected) where as before, I'd have to get off my backside and put it on the window sill!!! _________________ Steve
Posted: Thu Aug 10, 2006 4:30 pm Post subject: |
colin_thames wrote: | Sorry OldBoy, I've just found out that the version of POICapture for the TomTom Go 5.44 is version V1.06G. The only way I seem to be able to find this was by downloading it, then the Save As dialogue showed the file name.
Yes, you're right, the .mnu is different.
All I did was iopen the existing menu, change it around to how i wanted it to look, and then added bits I wanted from my old menu into it adding Page 4 in the process!!!
If you need help, shout. _________________ Steve
ras2000 Occasional Visitor
Joined: Feb 03, 2006 Posts: 4 Location: Lancashire UK
Posted: Tue Aug 22, 2006 2:51 pm Post subject: Version 6.150 TTG300 |
Hi Guys,
does any one have any issues with TT buddies being grayed out in the menu structure?, I do not seem to be able to get it to work... however my traffic still works ok so the connection is working ok I guess, but during the upgrade from v5 to 6 it wiped all my favaories and all my phone settings - speaking to TT support they suggested a reinstall which I am reluctent to do as mentioned above... I had previously moved the menus about to acomodate the POI speed cam capture on the 1st page... might this be the cause and if so does any one know wher I can get the standard "working" menu mnu file?...
Thanks  _________________ Rob Simpson
Tom Tom Go 300
2GB SD Card Upgrade
Sony P910i Phone For Traffic and stuff...
Tom Tom Traffic + Rocks !! |
Posted: Tue Aug 22, 2006 7:36 pm Post subject: Re: Version 6.150 TTG300 |
ras2000 wrote: | does any one know wher I can get the standard "working" menu mnu file?... | Just re-name, or remove, the tomtom.mnu file in the SdkRegistry Folder. _________________ Richard
Posted: Wed Aug 23, 2006 3:26 pm Post subject: Re: Version 6.150 TTG300 |
Oldboy wrote: | ras2000 wrote: | does any one know wher I can get the standard "working" menu mnu file?... | Just re-name, or remove, the tomtom.mnu file in the SdkRegistry Folder. |
Brilliant - works a treat!! thanks very much
Rob _________________ Rob Simpson
Tom Tom Go 300
2GB SD Card Upgrade
DennisN Tired Old Man
Posted: Sat Aug 26, 2006 8:43 pm Post subject: |
Since 6.15 I have a sneaking feeling that I now get TWO warnings for some cameras i.e. the beep goes off, then it goes off again, maybe 50 - 100 yards later. I can't be sure and I don't entirely object to getting two! But I really think I'm getting two warnings for at least one local camera (Gatso 12964@30 - Bristol, Brislington A4 eastbound) and the other week I was getting two for some temporaries on M4 (they've gone now so I can't check again). I use "Warn only when on route" (and in case you're wondering, I'm not confusing it with the gatso30 on the other side of the road earlier on).
Dennis |
Tradman Lifetime Member
Posted: Tue Sep 05, 2006 11:59 pm Post subject: Duplicate warnings. |
I have the same trouble as DennisN. Have updated to 6.15 with new voice prompts for the whistles and bells etc. on a trip to and through Wales via M4 and local roads was getting correct speed camera warnings OK plus an added red light warning at the same time, this happened with most cameras ( I don't think there was a visual red light warning). Have I added the camera database twice?, should I remove the sped camera database and start again if so how?. |
