Pocket GPS World :: View topic - go510 speed camera database
tranceporter
PostPosted: Wed Aug 09, 2006 8:58 pm    Post subject: go510 speed camera database Reply with quote
hi to you all. could anybody give me any information as to wether there may be a speed camera database for my new go510 which replaced my trusted 300 which worked perfectly with the database from here.
will need step by step instructions if so, cause bit of a dunce when it comes to playing with and moving files etc... thanks to anybody with any help.
Nathan. (help help)
PostPosted: Wed Aug 09, 2006 9:03 pm    Post subject: Reply with quote
Nathan, Welcome to the forums, the same database you used to use with the 300 will work wth the 510, as for a set-up guide have a read of THIS OK it was scripted around the 910 unit, but up to the part about Text To Speach the set-up is the same.
As your unit doesn't have the TTS feature simple select one of the warning sounds from the presented options - Mike
tranceporter
PostPosted: Fri Aug 11, 2006 12:42 am    Post subject: Reply with quote
hi Mike, well what can i say. a big thakyou for a start. had plenty of problems to begin with, in the end i had to resort to plugging my sd card into pc directly and copying relevant files across to 510 that way. very long winded but worked a treat all the same. go510 seems to be picking every camera. (did in demo mode anyway) will find out tomorrow in real time driving. only thanks to you though. a huge thanks again.
best regards
Nathan
p.s. i have deactivated the pre-installed camera warnings which were not a great help.
22.062 (12 Jun 24)
