Pocket GPS World :: View topic - Do it yourself traffic?
GPSBear
PostPosted: Sat Aug 05, 2006 12:25 pm    Post subject: Do it yourself traffic? Reply with quote
After reading all the broadcast traffic signal problems and also after trying to get to an appointment last night with three local major through routes being dug up for gas/sewers for weeks on end and being either closed or one way............... Crying or Very sad
Anyway. Does anyone know what the traffic thing actually downloads into a GPS such that it knows to avoid it? Because if it is a special POI then could we not build a road works database like the speed camera one?
OK it won't solve the instant jam problem due to sheer weight or accident, but there are enough long term road works that it might be useful.
swing
PostPosted: Sat Aug 05, 2006 1:10 pm    Post subject: Reply with quote
No, it's not as simple as just a list of POIs, as it contains start and end locations, the type of problem, and the expected delay. Certainly some long term roadworks are included in the data, but mainly on the trunk roads.
GPSBear
PostPosted: Mon Aug 07, 2006 11:34 am    Post subject: Reply with quote
OK so it is not a straightforward POI - But do we know how to do it?
Would be nice to do. For example every route from here ends up recalculating because I can't drive down the high street for 8 weeks! If I could only tell it that it was closed...........
swing
PostPosted: Mon Aug 07, 2006 12:13 pm    Post subject: Reply with quote
Indeed - that's an often requested additional feature - either the ability to request a reroute based on a road block, or an Avoid feature.
wilburforce
PostPosted: Wed Aug 09, 2006 11:39 am    Post subject: Like the idea Reply with quote
Actually i see no reason why a database could not be made similar to speed cameras. The problem lies with the updates.
Major long term road works ...yes
Short hold up probably wont work.
I would use them if they were available but who is going hold the list?
Nice idea. :o
GPSBear
PostPosted: Wed Aug 09, 2006 12:04 pm    Post subject: Reply with quote
We need to know *how* to get such info into the GPS first. If that can be done I doubt hosting will be that much of a problem - I might even do it myself.
swing
PostPosted: Wed Aug 09, 2006 12:41 pm    Post subject: Reply with quote
Personally, I'd prefer our efforts to be put into getting Garmin to fix the problem with the traffic modules, not coming up with a way around their problem.
Also - what will we do with the information - the units have no "avoid" option, so it would take a lot of work to avoid any roadworks, especially with most units only having 1 via point!
GPSBear
PostPosted: Wed Aug 09, 2006 6:25 pm    Post subject: Reply with quote
Well, for one thing it would be useful for folks *without* traffic receivers. Secondly the units *do* have an "avoid" option - It's triggered by whatever it gets from the traffic receiver. Hence the original question in this thread "do we know how to encode that?"
swing
PostPosted: Wed Aug 09, 2006 6:33 pm    Post subject: Reply with quote
A valid point about those without traffic.
As for having an avoid option, I'm not sure it does. The unit has the capability of working out a better route is available (based on road distance / average speed on those roads) - a few people have seen this kick in whilst driving even without the traffic module.
I think all the traffic module does is vary the average speed on particular roads, and then this "I've spotted a better route" algorithm comes into play.
I don't, for example, think it uses an actual file on the disk that we could create and pre-populate, I think it's all done in memory on the fly (although I may be wrong on this point).
GPSBear
PostPosted: Thu Aug 10, 2006 8:56 am    Post subject: Reply with quote
Daft thought time :-)
Nuvi's have USB. You can plug them into a PC, therefore they must be USB "slave" units. (USB is not peer to peer.)
TMC units plug into the USB port, therefore they must simulate a "controller or PC" type.
Now if we hooked a USB hardware sniffer between the two it ought to be possible to find out just what the TMC sends to the GPS. Once that is figured out then a similar data stream could be generated from a PC. Of course if you are correct about it all being done in memory then we are before we start. We could ask Garmin - But I doubt they would tell us :-)
swing
PostPosted: Thu Aug 10, 2006 11:28 am    Post subject: Reply with quote
Worth a try, although it's possible that Garmin have harnessed the "serial" bit of the USB spec and simply send traffic from one device to the other without anything fancy. Of course, that might make it easy to simulate...
22.055 (29 May 24)
