Beerbellybill999 Regular Visitor
![](modules/Forums/images/avatars/gallery/003.gif)
Posted: Fri Aug 04, 2006 8:58 am Post subject: |
I wonder if this is a problem with the Wizard. When i did it the old method I could search all the maptiles and had all the poi loaded. It could be that the wizard cancels the mapsource loader too early. I will have to test it myself.
I hope its not back to the old method! And if it is i might write a guide if i have time.
You can test it by turning of gps mode and simulating the route. Try using via and you can also review turns
For the time being you could always load all the places you want to visit onto the i3 as waypoints in the mapsource program. You can still use this to load them to the i3 _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed) |
Tizwas Occasional Visitor
Posted: Fri Aug 04, 2006 2:07 pm Post subject: |
Hello I'm new to all this, but having read loads of posts and taking the plunge and had a go at uploading a load of France and Austria Metroguide maps via the wizard, it seems to have worked.
I'm using a new 512mb card.... one quick question.... will I still get voice prompts? I can see the autorouting working as it calculates routes... etc.. but on the settings menu the voice choices seem to have gone.. it only displays text language options.
I see on the original SD card some voice files? Should they be copied accross?
Thanks. |
sanaar Occasional Visitor
![](modules/Forums/images/avatars/gallery/animal_doggy2.jpg)
Posted: Sat Aug 05, 2006 2:37 pm Post subject: |
Could it be that im using a 1gb card?
Ive seen several comments about a 512mb being the max.
Beerbelly/anyone ? |
Posted: Sun Aug 06, 2006 11:55 am Post subject: |
I have a 512,and i have checked,and I have the same problem if i use the wizard. It looks like i will have to use the manual method for the time being.. I will email the author of the wizard to see if he can correct it
You can still use it anway. autorouting still works but you will have to load waypoints before you go via mapsource _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Posted: Mon Aug 07, 2006 9:44 am Post subject: |
It is now working for me. see this thread I was involved in.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=43685
I tried 3 different area's France, UK and Netherlands and selected a couple of maptiles from each and loaded them at the same time. When I go to address search it gives me 3 countries to choose from ENGLAND,FRANCE and NETHERLAND.
see if it works for You! _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Posted: Mon Aug 07, 2006 12:30 pm Post subject: |
Still no joy here!!!
I can select the map tiles in mapsource and start the wizard.
It builds an index file but doesnt seem to transfer it to the unit.
I then transfer maps to the unit ok.
When i try and do a search under "where to" there is no address option so i dont get a country list.
Any thoughts? |
Posted: Mon Aug 07, 2006 1:21 pm Post subject: |
are you running the latest version of Mapsource? Mine is 6.11.3. _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Posted: Mon Aug 07, 2006 1:32 pm Post subject: |
Tizwas wrote: | Hello I'm new to all this, but having read loads of posts and taking the plunge and had a go at uploading a load of France and Austria Metroguide maps via the wizard, it seems to have worked.
Thanks. |
Yes you will get voice prompts, English(British) is already loaded. You have just lost the facility to Change the voice to other languages. If you do want to do this you will have to copy via card reader the Voice folder _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Posted: Mon Aug 07, 2006 2:11 pm Post subject: |
:D Brilliant thanks.... |
Posted: Mon Aug 07, 2006 5:22 pm Post subject: |
Almost there !!
Loaded maps successfully and can search and find cities
However, I cannot use the address search.
"go to", then "address", but as soon as i enter anything it says not found.
Does that mean it is only a routing map from city to city.
If i simulate a journey i can get there with full mapping down to street level.
Gives me turn by turn directions ok.
I just cant enter an address.
Am i missing something? |
Posted: Mon Aug 07, 2006 8:15 pm Post subject: |
AMENDMENT
When i do a search address it asks for a "State" at the next screen.
No matter what i enter it says "not found".
if i do a search for city i can select any one in the list
Then i can route to another. it gives centre point to centre point for the 2 cities.
There must be a way of inputting addresses but im totally stumped. |
Posted: Tue Aug 08, 2006 8:58 am Post subject: |
sanaar wrote: | AMENDMENT
The fact you prompted for state means that you have no index whatsoever. I don't know what you have done.What type of i3 do you have,the older one with the mapping on the external card or the newer with inbuilt mapping? Mine is the older! _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Posted: Tue Aug 08, 2006 1:44 pm Post subject: |
Older one with external mapping.
I can see it building an index file but dont know if its transferring to i3.
Does it store it somewhere temp on pc and i can transfer it onto the card manually.?
Thanks for your patience in all of this |
Posted: Tue Aug 08, 2006 1:54 pm Post subject: |
sanaar wrote: | Older one with external mapping.
the wizard appears to allow mapsource to create the index file and then cancels it before it starts creating the actual map. I assume it must have copied this to a temp location and combines this with the maps data into an img file and then uploads it with sendmap. I works with mine. I can't think how you could be doing it any different. I take it you leave mapsource alone when the wizard cancels the index bulid rather than click on the prompt to abort/cancel? _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Posted: Tue Aug 08, 2006 2:05 pm Post subject: |
Once the wizard kicks off, i leave well alone.
I dont see any prompt to abort/cancel.
Did you load the maps while on ver2.7 or another?
Ive tried with the card in the unit and in a card reader and get the same results.
Its really frustrating to have everything as it should be except "adress search.
Maybe I"ll send you my card and you can do it for me !!!! ![Laughing Out Loud](modules/Forums/images/smiles/icon_lol.gif) |
