Pocket GPS World :: View topic - Garmin nuvi 310D GTM12 TMC problems
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 42, 43, 44  Next
ColinG
PostPosted: Tue Aug 08, 2006 12:01 am    Post subject: Reply with quote
Hi n4nick,
You have the very latest SW version 2.7 which I've coincidentally just upgraded to this evening. I subscribed to email notification from Garmin but not received.
You will only get confirmation of the GTM software Version when GTM unit is plugged in and powered up.
Mine says (pre SW upgrade to 2.7) GTM 3.60.
Hope this helps.
ColinG
TomTom 740 Go Live
n4nick
PostPosted: Tue Aug 08, 2006 12:23 am    Post subject: Reply with quote
Thanks ColinG
Just popped out to the car to get the GTM12 and I am now showing GTM SW3.6. I was hoping a lack of software was the key to my problems but obviously not! Too late to be messing around anymore with this now. Crying or Very sad
Goodnight!
n4nick
PostPosted: Tue Aug 08, 2006 12:41 am    Post subject: Reply with quote
Software up-to-date (although I can't find GTM3.7 mentioned above) and message count ticking up in the diagnostics screen entered via the trip computer however still not traffic data available in the traffic screen itself! Crying or Very sad Fingers crossed for tomorrow! Nick
banjo12
PostPosted: Tue Aug 08, 2006 8:35 am    Post subject: Reply with quote
So all in all,
this nuvi, may or may not pick up traffic info due to faulty power lead, aerial, or transmitter, if you do get the info it can be wrong, it can direct you down narrow lanes.
In my opinion I have been sold a lemon for £400, is watchdog still on the telly ?
banjo12
PostPosted: Tue Aug 08, 2006 8:46 am    Post subject: Reply with quote
New software update is now available http://www.garmin.com/support/download_details.jsp?id=1529
RDS
PostPosted: Tue Aug 08, 2006 8:55 am    Post subject: Reply with quote
Interesting to note amongst other things like Estonian text language
and Croatian, Greek, and Slovenian Pre-recorded Voices the V 2.7 update contains
'Added fix for powering on from charge mode with GTMxx connected '
Is this the solution we've all been waiting for ?
Woms
PostPosted: Tue Aug 08, 2006 10:15 am    Post subject: Reply with quote
This looks promising. Fingers crossed.
swing
PostPosted: Tue Aug 08, 2006 11:00 am    Post subject: Reply with quote
n4nick wrote:
Out of interest what doesn't sound quite right? :D
It was your general description of how the traffic data was / wasn't working that didn't sound like things were working quite right, and I know that at least one of the firmware updates for the GTM has made the whole process more reliable, hence my question.
If you haven't already seen, there's a new version of the Nuvi firmware out now, which does have 1 minor GTM fix in it, so might be worth applying.
swing
PostPosted: Tue Aug 08, 2006 11:03 am    Post subject: Reply with quote
No, I don't think it is - this is a particular issue with problems if you, for example, you power down the Nuvi whilst everything is plugged in, and then power it back on - that's different to the majority of problems which occur on the first power up when you first plug everything in. However, it may still help, but I've yet to try it.
swing
PostPosted: Tue Aug 08, 2006 11:06 am    Post subject: Reply with quote
Sorry, my mistake, the latest is GTM v3.60.
swing
PostPosted: Tue Aug 08, 2006 11:10 am    Post subject: Reply with quote
Agree, insufficient power supply, placement of the aerial, or a weaker transmitter.
Apart from the odd incident, I've yet to see a unit receiving a constant stream of traffic data (*) from being widely wrong, or out of line with a number of online traffic websites I compare it against.
(*) If a unit is no longer receiving a stream of traffic it will normally continue to display the old traffic information, which may result in the appearance of unreliable traffic data.
banjo12
PostPosted: Tue Aug 08, 2006 11:18 am    Post subject: Reply with quote
I had installed the beta software which meant multiple stabbing of the on/off switch to get the unit to work followed by out of sync video etc, after the last upgrade this now seems to have been cured.
benmahy
PostPosted: Tue Aug 08, 2006 11:27 am    Post subject: Reply with quote
I have installed the latest firmware and I can say that it does fix some of the bugs:
1. The car charger is now GREEN not RED when on charge Smile
2. The MP3 play now remembers where you last were on a track - 2.52 beta did not.
3. The TMC now (in diagnostics) locks onto a channel instantly - although I have yet to see a traffic report come through (i was only sitting in my car for 1-2 mins, will try later when I go out)
4. I have a level in the diagnostics of 15 (on channel 1)
I will keep looking for other improvements and let you all know, as I am sure you are all as frustrated as I am.
Ben
capsecum
PostPosted: Tue Aug 08, 2006 11:46 am    Post subject: Latest firmware impact on TMC Reply with quote
Been following the thread for a while, tried the update too.
Unit still fails to get a lock on a chanel (does hover around channel 30). Best signal levels are around another channel, but will not provide traffic data. I have discovered the unit has now picked up V-Trafic (europe).
I am in deepest Lincolnshire it seem ironic the unit can pick up v-traffic but not tell me when the A46 is blocked.
If I travel to Nottingham TMC appears to work fine
just one query, the power leas supplied with my Nuvi 360 only has a red LED, anyone else like this?
JoshT
PostPosted: Tue Aug 08, 2006 3:14 pm    Post subject: Reply with quote
My LED is red also; even when not powering the unit.
I've upgraded my Nuvi 310D to release 2.7 software. It appears to have made some difference to reception of TMC. Previously wouldn't recieve unless internal battery fully charged. Now appear to pickup reception when over two bars (ie half charged)
Hasn't resolved other issues I have:
It will route from my hometown to South of France but not to Cherbourg! Get routing calc error insufficient memory.
I also have a problem with searching for town names in France. I store French maps on the SD card. I think the unit searches base database first without looking at the supplementary maps in some cases.
Does anybody know what happens to routes when you upload them from mapsource to the Nuvi? I was trying to up avoid a road which is being dug up. Works on mapsource but route doesn't appear to upload to Nuvi.
Does anybody know how you can route via a ferry crossing? I've tried all sorts of things to no avail!
Page 8 of 44
22.055 (29 May 24)
