tdowney98 Occasional Visitor
Posted: Tue Aug 08, 2006 12:31 am Post subject: Adding uk voice and killing your C510e |
I have copied over both thomas amd philappa voice zips to my c510e now I can't get beyond the starting screen for mio map also contacts crashes when i click on it. It all worked great until I connected via bluetooth.
So I click on contacts I get an error message
Contact
An attempt was made to access an unnamed file past its end
then click ok I get
Fatal application error
Application contact.exe has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor
Program: contact.exe
Exception:0xC00000005
Address: 0000045E
Then if I try to load mio map I get as far as "starting" then nothing
I tried turing it off and on I done several insert a pin reset all to no joy any ideas?
Does anyone have a file listing so I can check to see if I have deleted a file?
Regards and thanks in advance |
CeeJay Frequent Visitor
![](modules/Forums/images/avatars/gallery/avatar_sp_018.jpg)
Joined: Jan 06, 2006 Posts: 360 Location: East Sussex
Posted: Tue Aug 08, 2006 12:43 am Post subject: |
Hi tdowney98.
to the madhouse.
Have you tried a hard reset using the switch at the bottom of the unit.
I think I read you have to leave it off for a minute or so.
Give that a try and get back to us.
CeeJay. |
Posted: Tue Aug 08, 2006 12:48 am Post subject: |
Doh, just remembered.
I had some grief with one of the male voice downloads, can't remember if it was US male or UK male. I ended up deleting them anyway, then after a reset normality was resumed.
Phillipa works OK.
CeeJay. |
Posted: Tue Aug 08, 2006 8:56 am Post subject: |
I will try deleting both and seeing what happens after a hard reset with the on off button and short period for the device to go a way and think about the error of its ways ! :D
If that does not work is is possible to get the c510e back to factory defaults with the install disk? My worry is that during the recopy and delete of the voice file I could have deleted a system file or are they safely kept way from the flash disk?
Thanks in advance.. |
