Pocket GPS World :: View topic - Converting pushpin (Autoroute) to ov2
Ian_W
PostPosted: Mon Dec 22, 2003 7:16 pm    Post subject: Converting pushpin (Autoroute) to ov2 Reply with quote
On TomTom's site there is reference to a package called pushpinov2 - but the link ends up at the safty camera page here.
A google search drew a blank, so I wondered if anyone knew of the package so I can create an ov2 database via autoroute.
Thanks.
Matok25
PostPosted: Tue Dec 23, 2003 12:03 am    Post subject: Re: Converting pushpin (Autoroute) to ov2 Reply with quote
Ian_W wrote:
Thanks.
Hi Ian
you need the microsoft Programm Mappoint and the Program Pinstoile
(yo can find it here http://ourworld.compuserve.com/homepages/gilles/home.htm
The program will export all your Pushpins to an real ascii file so you can use it after a little bit of modification in TomTom
you need also the Program makeov2 from Tomtom tom make from asc file an ov2 file
I can send you an google translatet step by step instruction to do this
Best Regards
Uwe
you will never have a second chance to make your first impression
Oldie
PostPosted: Tue Dec 23, 2003 10:03 am    Post subject: Re: Converting pushpin (Autoroute) to ov2 Reply with quote
Ian_W wrote:
Thanks.
The TomTom link should point to the Downloads area on this website. Look in the "PC" area of "POI Icons and Converters" and you will see the program that you were looking for (and others that you may find useful).
Ian_W
PostPosted: Tue Dec 23, 2003 2:23 pm    Post subject: Reply with quote
Thanks guys - I have got my psp file from AR 2003, started the conversion proggy, but all it does is site there saying 'Reading from... /file/name.psp'
The file is only 1kb, so not sure why it isn't working.
Back to the drawing board. Crying or Very sad
Oldie
PostPosted: Tue Dec 23, 2003 4:48 pm    Post subject: Reply with quote
Ian_W,
The program will just sit until you tell it where to save the output. Click the Save button or use Save As under File.
If you have already tried that, then send the .psp file to me and I will have a look at it for you.
PS As you are exporting from AR 2003 there are likely to be some spurious offsets applied to the converted points. I have not been able to find out the cause, but the finger points at Microsoft Sad
Ian_W
PostPosted: Wed Dec 24, 2003 3:10 pm    Post subject: Reply with quote
Doh! Thank you. Didn't realise that.
Next question Wink Do you know of anyway to combine ov2 files - reason being the points I need over a wider area of the UK, than I can export from AR - so wondered if there was any way that I can get all the various points in one ov2 file?
BTW - the points are pretty accurate for the 2 or 3 I have looked at.
Thanks for all your help - appreciated.
Oldie
PostPosted: Wed Dec 24, 2003 3:48 pm    Post subject: Reply with quote
I have written a program POIManager that you can use to merge TTN POI overlays. When updating a master file it will check the proximity of the POI in the update file and let you skip any duplicates. The program is in the "POI Icons and Converters" section under Downloads.
I am near to finishing an Embedded Visual C version of the program which will run on the Pocket PC. The eVB program which is also available in the Downloads area is slow and can cause problems if you are using a Pocket PC 2003 PDA.
Have fun,
Ian_W
PostPosted: Wed Dec 24, 2003 4:04 pm    Post subject: Reply with quote
Thanks - will give it a shot :D
Ian_W
PostPosted: Wed Dec 24, 2003 6:07 pm    Post subject: Reply with quote
Spoke too soon - some of them are 2 miles out Crying or Very sad - will see if AR 2004 is a better match on them. Or perhaps go back to an earlier version.
PONDEROUS
PostPosted: Sat Oct 15, 2005 4:16 pm    Post subject: Reply with quote
Hi, Richard (Oldie).
I apologise of this has been covered before, but I have scoured the forum without success.
I tried your POIConverter with Pocket Streets pushpins. The utility is very easy to use, thanks very much. I'm having real problems using the pushpins with TomTom 3, though.
About 30 of the 60 or so addresses I visited in Liverpool last week were many streets away from their correct location in TomTom, but they were dead right in Pocket Streets itself.
Is there a solution to this, and will it make any difference when I install my TT5 upgrade, please?
Paul
PONDEROUS
PostPosted: Sat Oct 15, 2005 4:42 pm    Post subject: Reply with quote
I expect that you know already, but I tried POIEdit, on my LIVERPOOL.ASC file from Autoroute, and the results were no better.
In other words, neither using another application nor eliminating the production of a Pocket Streets pushpins file made any difference.
Thanks.
Paul
PONDEROUS
PostPosted: Sat Oct 15, 2005 4:51 pm    Post subject: Reply with quote
Sorry, just to make the situation absolutely clear: I am using Autoroute and Pocket Streets 2005 versions.
Oldie
PostPosted: Sat Oct 15, 2005 6:29 pm    Post subject: Reply with quote
Paul,
If you have the information as pushpins in AutoRoute then use POIConverter to read the data from the map file (*.axe). There is a Microsoft "feature" that was introduced after AutoRoute 2001 that introduced variable offsets when extracting data using Pocket Streets files (*.psp). Make sure that you close AutoRoute before running POIConverter.
Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405
PONDEROUS
PostPosted: Sun Oct 16, 2005 10:09 am    Post subject: Reply with quote
That did the trick.
Thank you very much for your help and for your POIConverter. It gives me with what I have needed for a long time: seamless browsing of a map of my addresses and navigation to them.
Could you please tell me how to pay for the utility, as I can’t see anything about this on your web site.
Paul
Oldie
PostPosted: Sun Oct 16, 2005 12:16 pm    Post subject: Reply with quote
Paul,
I am pleased to see that your problem is sorted. All of my programs are free :D as, in the main, they have been written for my own use.
22.055 (29 May 24)
