Pocket GPS World :: View topic - Brand new i3 and full SD card ?!?!
Goto page Previous  1, 2
poppycat
PostPosted: Thu Aug 03, 2006 4:52 pm    Post subject: Reply with quote
Thanks I check that out
rigga
PostPosted: Thu Aug 03, 2006 11:13 pm    Post subject: Reply with quote
Beerbellybill999 wrote:
I think you are getting confused between the POI already loaded by Garmin(these can't be overwritten unless you change the map) and the Custom POI you can add(ie speed camera.s etc).
If you map is stored internally then you will need to load the custom POI to the card rather than the internal memory via a card reader!
Confused?? more than likely Laughing i think your right that the standard garmin loaded poi was throwing me off track...... so much info on here but hard at my age to digest it all at once Smile as it came with an sd card i take it map (v8) are stored on there?...... or can i just remove the card,see if he unit works and then know the map is internal?...... the last unit in stock,but not guaranteed the latest type of unit i guess.
Page 2 of 2
22.064 (26 Jun 24)
