030303 Occasional Visitor
Posted: Wed Jul 26, 2006 11:53 pm Post subject: My does not see my tomtom G0? |
When I connect my tomtom go700 via usb to my PC it no longer shows up. The screen remains blank on the tomtom. If I turn the tomtom on it makes to difference. the battery in the tom tom is fully charged.
Any help please. |
Oldboy Pocket GPS Moderator
Posted: Thu Jul 27, 2006 7:39 am Post subject: |
Does the TT come on normally?
If Yes, check that the USB lead is firmly plugged in both ends.
Have you tried another USB lead? Also the TT has to be on anyway when connected to the PC. _________________ Richard
autostratus Occasional Visitor
Posted: Thu Jul 27, 2006 10:53 am Post subject: |
Same problem here with TT Go 700. Updated using the Home program from TomTom Site this morning to the new version 6.140. All works ok but 700 will not connect to PC. Connect as normal and switch on - mapping comes up and the PC says no connection.
On one occasion a screen came up on the 700 and asked if I wished to connect to the PC. On hitting the YES button it connected - but not since.
Any answers anyone. Seems to be as a result of the upgrade. |
Posted: Thu Jul 27, 2006 2:20 pm Post subject: oldboy |
same story as autocruise, did the update which went ok. now when I connect via usb the tomtom does not get seen by the pc. checked "my computer" not shown there either try with tomtom on and off. tried another usb lead and different usb sockets no luck.
the tomtom screen stays off does not go into sync mode. when i put it in the car it works ok. |
Posted: Thu Jul 27, 2006 8:11 pm Post subject: |
Have you tried a Reset? Pin-in-the-hole. Hold it in for a few seconds. _________________ Richard
alix776 Pocket GPS Moderator
Posted: Thu Jul 27, 2006 8:12 pm Post subject: |
are you connecting through a USb hub if so try it direct to the port _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Thu Jul 27, 2006 9:10 pm Post subject: |
tried the pin once made no difference, using usb on computer no hubs. not sure if i need to use the pin over & over till it works but scared it might damage the tomtom. anyone had results this way. I have emailed tomtom awaiting to see if i get any reply.
any other tips in the meantime would be helpful
[tried connecting to the pc first then turning on the pc to see if it would get detected = it corrupted the pc bios had to clear the cmos for a restart of pc. ] |
Posted: Sat Jul 29, 2006 5:19 pm Post subject: sorted |
the new update pauses longer than expected on the flash screen. after waiting a minute or so the option comes up asking to connect to a computer. ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
wez99 Regular Visitor
![](modules/Forums/images/avatars/187705837742efd27cf1908.jpg)
Posted: Sun Jul 30, 2006 5:40 pm Post subject: |
Thanks Oldboy that worked for me also, Should have been the first thing to try, but as every thing else was working fine I never considered it.
BTW you seem a knowlegable chap, so do you know what files to delete to remove the now redundant "cat apps". _________________ TomTomGo730 |
Posted: Sun Jul 30, 2006 9:23 pm Post subject: |
wez99 wrote: | ... so do you know what files to delete to remove the now redundant "cat apps". | All the Files are in the SdkRegistry and, from memory, Catapps Folder. _________________ Richard
gadget_sa Frequent Visitor
![](modules/Forums/images/avatars/28214692144d877d7ede33.jpg)
Joined: Dec 02, 2005 Posts: 334 Location: Wiltshire, UK
Posted: Mon Jul 31, 2006 10:28 pm Post subject: |
I'm touching wood whilst I write this.
Upgraded to 6.14 and not had any of the issues you guys with700's describe. _________________ Steve
iPhone 6 with Western Europe & CamerAlert |
