nitelife Occasional Visitor
Joined: Apr 11, 2006 Posts: 51 Location: Reading, Berkshire
Posted: Thu Jul 27, 2006 9:34 pm Post subject: Strange... |
Ive just picked up a new i3 from comet, expecting it to be of the new variety, i.e maps inside.
It wasnt, which is fine, it comes with firmware version 3.00 and audio 2.5.
Well I was under the impression that 2.5 was only shipped with the internal memory models?
When I try and upload my poi's and speed camera database (I used to have an i3 a little while ago) I keep getting the message "There is not enough space on the GPS to store all the points of interest. Please reduce the number of points and try again"
Now there's plenty of space on the card, around 60mb, and the pois on disk take up a couple of meg. Its not a mistake with the card because I tried turning on the unit without it and it asked me to give it some maps.
Any ideas? |
mk_graham Regular Visitor
![](modules/Forums/images/avatars/gallery/starwars15.jpg)
Joined: Jul 13, 2006 Posts: 200 Location: Milton Keynes UK
Posted: Fri Jul 28, 2006 1:06 am Post subject: |
Hmmm, sounds like you leaving the card in the i3 and are not using a card reader/writer with POILoader to load the POI's?
I have the very same unit from Comet (2 weeks old) - the above works for me - I have 44k custom POI's loaded to the card. _________________ Garmin i3 gone (sold on eBay)
V7 PMD 1400 with Western Europe Maps gone (sold in local paper)
TomTom Go 720 WE Maps (for sale)
iPhone with Sygic Mobile Maps (Europe) - having problems |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Fri Jul 28, 2006 10:37 am Post subject: |
nitelife ..you must be doing something wrong mate...my one week old i3 from comet came with a card and i loaded my pois with no problems... _________________ *************************** |
Beerbellybill999 Regular Visitor
![](modules/Forums/images/avatars/gallery/003.gif)
Posted: Fri Jul 28, 2006 12:30 pm Post subject: |
Its possible that you do have a new one with internal memory but they also supplied a transflash card by mistake.
In which case make sure you select the external card on th POI loader drop down list _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed) |
Posted: Fri Jul 28, 2006 1:39 pm Post subject: |
mk_graham wrote: | Hmmm, sounds like you leaving the card in the i3 and are not using a card reader/writer with POILoader to load the POI's?
I have the very same unit from Comet (2 weeks old) - the above works for me - I have 44k custom POI's loaded to the card. |
I never did that on my old one, just connected via the USB cable and it went through the unit without taking the card out. I didnt know you could even copy them onto the card directly (if thats what your saying).
zogman wrote: |
Yeah I know what you mean, you cant really go wrong can you? Just plug it in fire up the loader and away you go (usually!).
Beerbellybill999 wrote: |
Thats why I tried turning it on without the card, but it says to connect to a pc and download maps.
If I use gstart then the poi loader doesnt ask me to select a device. If I load it manually using windows explorer I get Streetpilot iŁ (Unit id xxx) and Removable disk E:, which is the card reader in my printer.
Any other ideas???
![Confused](modules/Forums/images/smiles/icon_confused.gif) |
RiTSo Occasional Visitor
![](modules/Forums/images/avatars/186761438544ca090642fd3.jpg)
Posted: Fri Jul 28, 2006 1:46 pm Post subject: |
Not an answer but I've had the same problem as you are experiencing!
I posted about it in the Garmin newsgroup yesterday:
Click Here!!
I just reset my unit and was going to try the advice above to see if it works. |
Posted: Fri Jul 28, 2006 1:58 pm Post subject: |
Beerbellybill999 wrote: | In which case make sure you select the external card on th POI loader drop down list |
Can't see this option at all in the POI Loader!
When the POI Loader bootsup I can only press next, this then takes you to the screen with three options, BROWSE - to locate the folder on your PC, UNITS - to set KPH or MPH and MODE - Express or Manual.
Never any option for Unit/Card available that I can see. |
Posted: Fri Jul 28, 2006 2:01 pm Post subject: |
nitelife wrote: | If I use gstart then the poi loader doesnt ask me to select a device. If I load it manually using windows explorer I get Streetpilot iŁ (Unit id xxx) and Removable disk E:, which is the card reader in my printer. |
I don't see anything when I try to access the unit via Windows Explorer, just have my normal drives available. |
Posted: Fri Jul 28, 2006 2:37 pm Post subject: |
After doing a bit more digging Ithink the answer is that you cannot write directly to the memory card via the i3 unit. If you try to do this the data will only be written to the unit itself.
It seems that a card reader/writer is required to access the card directly.
Details can be found HERE!
As an aside it also appear that the latest version of PoiLoader is flawed slightly and the recommendation is to stick to v2 for the time being, which can be found HERE.
Looks like I'm going to have to get me a card reader and/or adaptor to sort this out! |
Rubbish, just called Comet to tell them what is happening and they told me to call Garmin directly as they are the approved repairers and they wont take anything back if opened!
That doesnt sound legal, and the number they gave was wrong! |
Posted: Fri Jul 28, 2006 2:42 pm Post subject: |
RiTSo wrote: | After doing a bit more digging Ithink the answer is that you cannot write directly to the memory card via the i3 unit. If you try to do this the data will only be written to the unit itself.
Ahh ill give that a try then, maybe there is yet a new hybrid version which has memory and card usage somehow.
Just backing up my card now!
Just in case you've got one without realising, alot of mobile phones come with sd card adaptors these days, thats what im using to read mine in my card reader... |
Posted: Fri Jul 28, 2006 2:49 pm Post subject: |
nitelife wrote: | Just in case you've got one without realising, alot of mobile phones come with sd card adaptors these days, thats what im using to read mine in my card reader... |
I reckon I must have every type of card, every type of adaptor and every type of slot available......ecept this one!!
Just got a new SE K800i, but that uses the M2 memory from Sony, didn't get an adaptor with that though anyway!!
Let us know how you get on. |
Posted: Fri Jul 28, 2006 2:52 pm Post subject: |
W O O O H O O O O O ! ! ! !
I think that worked!!
This is NOT the way it worked with my previous Garmin I3, and actually seems quite silly to force you to use a card reader to update with!
Im not impressed with Comet trying to fob me off though.
Ahh well, ill bear it in mind for the future! But im happy for now!
Just gotta do a little more testing to make sure im not going mad, but I can see stuff in Custom Points..
so, so far so good. Gonna go outside so it can work out where I am and then test it.
Good luck! |
Posted: Fri Jul 28, 2006 2:53 pm Post subject: |
Any chance you could post me your adaptor???
Glad you're sorted out any way!! |
Posted: Fri Jul 28, 2006 3:20 pm Post subject: |
Get a card reader and we might be able to sort something out ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
