Pocket GPS World :: View topic - I3 Custom POI's
I3 Custom POI's
mussey1
PostPosted: Thu Jul 27, 2006 5:02 pm    Post subject: I3 Custom POI's Reply with quote
It appears that in each category within custom poi's it is only possible to view the top 50 that are nearest to the units current position.
i.e it will only show the nearest 50 gatsos or mobile camera locations.
Is there any way of viewing more than 50 in a single category??
I want to enter approx 100 pois into one .csv file, but would like to be able to see them all in a scroll down list on the I3 and decide which one to navigate to.
I could add them as favorites, but then I wouldn't be able to add proximity alerts etc.
Is there a way round this??
Thanks.
Mussey1.
trevf
PostPosted: Thu Jul 27, 2006 10:49 pm    Post subject: Re: I3 Custom POI's Reply with quote
mussey1 wrote:
Thanks.
Mussey1.
Sounds like you have Firmware 2.82. It works in all other versions, just not 2.82
Garmin i3
Firmware 3.4
mussey1
PostPosted: Thu Jul 27, 2006 11:33 pm    Post subject: Reply with quote
Thanks for the reply.
I regressed from 3.10 to 2.7.
I can see all the different categories of pois okay, however if for example I was to open the UK_Gatso file I will only see the nearest 50 to my location as opposed to all 3000+ in the UK.
Is there any way to view them all at the same time??
Thanks.
Mussey1.
trevf
PostPosted: Thu Jul 27, 2006 11:47 pm    Post subject: Reply with quote
I could be wrong but if you put in some details (e.g. under ASDA enter town name it should filter it alphabetically.
mussey1 wrote:
Thanks.
Mussey1.
Garmin i3
Firmware 3.4
mussey1
PostPosted: Fri Jul 28, 2006 12:24 am    Post subject: Reply with quote
Still no joy!!
Can only see 50 nearest to my current position.
Ah well....
Mussey1.
PostPosted: Fri Jul 28, 2006 1:26 am    Post subject: Reply with quote
The i3 will only display the nearest 50 POI, my unit has vs2,7 with vs8 maps loaded (I never carried on updating it due to the problems others were reporting - its stable and does what I want so I leave it alone) - I think the nearest 50 is as good as you are going to get with the i3 unless someone knows different, I have never managed to list more than this for a single POI category.
The only way I could think of to overcome this is to create your own POI file of the areas you want listed across the country, keep the quantity less than 50 in total within the single POI category and the device should list the entire lot, if you need more than 50 create a second category and place the remaining POI into this file - name them and differentiate the two files using North / South or East / West, or by town name if they are in a compact area etc - Mike
PaulB2005
PostPosted: Fri Jul 28, 2006 9:18 am    Post subject: Reply with quote
It's a limitation of the i3.
mussey1
PostPosted: Fri Jul 28, 2006 9:53 am    Post subject: Reply with quote
Thanks for the responses.
Cheers!
Mussey1.
22.071 (03 Jul 24)
