Posted: Fri Jul 28, 2006 12:35 am Post subject: |
It will work no problem, just select the TomTom ov2 file fromat, then the database format you require (single file/ consoladated by type or speed zoned (the best IMHO) then unzip the download, and copy/ paste the files straight to the sat nav, paste the files into the GB map folder then configure the warn when near POI for each camera type. this is located in preferences/ manage POI - Mike |
Menenlily Occasional Visitor
![](modules/Forums/images/avatars/117312491544c7ff2fbf810.jpg)
Joined: Jul 26, 2006 Posts: 14 Location: Stur, Dorset, UK
Posted: Fri Jul 28, 2006 1:01 am Post subject: |
Wow, thanks so much for the fast response - I never imagined I'd get it done tonight! :D Everything's gone onto the TT1 and it's all marked up. Just need to test it out now. Where shall I go ........... |
Posted: Fri Jul 28, 2006 1:08 am Post subject: |
Try using the "Advanced Planning" option and set a route past a few known local cameras, if you don't have any near by try entering a departure post code of FY43NN, and a destination of PR41AX (any house numbers that the unit will accept - try number 1 in each case) you should get a Gatso Warning followed by a Mobile warning within a couple of mins.
To view the route select "view Route" then "show Route Demo", set it to a speed of 100% before pressing done.
Its late so why bother going out when you can do this check in the comfort of your house? - Mike |
Posted: Fri Jul 28, 2006 1:33 am Post subject: |
Indeed
Thanks again, good suggestion. |
FazerUK Lifetime Member
![](modules/Forums/images/avatars/19986321594676bd60aa311.jpg)
Joined: Nov 18, 2004 Posts: 242 Location: Wrexhaml, UK
Posted: Fri Jul 28, 2006 3:15 am Post subject: |
Just installed the Home software and the upgrade 6.140, and it worked fine so far, and I like were I can put a password on it now, its a start to help someone else using it. _________________ TomTom Go 700,
with External Antenna, External Mike
App v7.160, OS:2324, GPS v1.21, Boot 5.4201
Western_Europe-Map v650.1127 |
Posted: Fri Jul 28, 2006 7:41 am Post subject: |
FazerUK wrote: | I like were I can put a password on it now, its a start to help someone else using it. | I thought the idea was to deny others from using it not help them - Mike |
Oldboy Pocket GPS Moderator
Posted: Fri Jul 28, 2006 7:43 am Post subject: Re: Got new TT1 - V 6.14 already on it - will PGPSW camera w |
Menenlily wrote: | ... and the navigator version that's on the TT One is V 6.14. Not listed as an option on the download site. | V6.14 is downloaded only via TT Home. This is a free download from www.tomtom.com
Menenlily wrote: | Does anyone know if any of the download files will work with this version? | All TT Devices use OV2/BMP File combinations for Custom POI's, and they are not Version specific.
Menenlily wrote: | Two weak suckers in a row can't be a coincidence, can it? Any suggestions anyone? | Are you using it where the screen is curved? Any curvature will make it harder for the sucker to work. _________________ Richard
Posted: Fri Jul 28, 2006 10:06 am Post subject: Windscreen holder |
Richard,
Thanks for your input. I realise now that when I posted my original plea for help I was looking at the POI capture software versions (D'oh) not the speed camera download page.
I don't know if you're familiar with the windscreen in a Disco, but it's very shallow and steep, and to the eye seems quite flat, too. I'll try it on other areas - there must be a reason why it's not sealing properly. |
CHEDS Regular Visitor
Posted: Fri Jul 28, 2006 11:55 am Post subject: |
How many poi's can you have with Version 6.14 ? |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Fri Jul 28, 2006 1:34 pm Post subject: |
Supposed to be 100, but I haven't tried yet! _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Fri Jul 28, 2006 7:41 pm Post subject: |
Yes, a 100.;) _________________ Richard
algypan Lifetime Member
Joined: Apr 30, 2006 Posts: 84 Location: Barry South Wales
Posted: Fri Jul 28, 2006 10:46 pm Post subject: |
I have a tomtom one I was told by LUTZ about version 6.14 so I downloaded tomtom home and automatically updated through that and it works fine with the camera download and also the voices I hope that helps |
alpha117 Occasional Visitor
Posted: Sat Jul 29, 2006 7:42 am Post subject: |
Is the 6.14 update for the 510, when I check for updates from TT home I get no updates avaible
Clive |
Posted: Sat Jul 29, 2006 3:24 pm Post subject: |
alpha117 wrote: | Is the 6.14 update for the 510, when I check for updates from TT home I get no updates avaible | The 6.14 update is for non-x10 Devices. It overcomes some SD Card issues. So I've been told.
It does not give the x10's any extra functionality. _________________ Richard
dieselnutjob Occasional Visitor
