Pocket GPS World :: View topic - Recorded POI's end up in wrong location (too late)
chrisofsweden
PostPosted: Thu Jul 27, 2006 12:11 pm    Post subject: Recorded POI's end up in wrong location (too late) Reply with quote
If you record a poi in the normal way, the poi will end up in the wrong location if you are on the move.
I'm wondering if there an addon like the "poi capture" that records the poi at the instant you press record, but lets you specify category and name etc.
I'm using a iPaq 2790 and TomTom 5.21.
Thankful for any replies.
Oldboy
PostPosted: Thu Jul 27, 2006 8:00 pm    Post subject: Reply with quote
You could use the same process as is used to convert Favourites to POI's.
Capture the location with POICapture, and use a similar method that I posted here.
Use Find to get the location from PocketGPSCameras and then Add as POI to any Category that you require. You will need to change the text obviously.
You can then Delete the location from the POICapture File, (use Manage POI), so that it doesn't get mixed with any cameras.
TT Via 135 App 12.075: Europe Map v1135
22.094 (25 Sep 24)
