Pocket GPS World :: View topic - Map refuses to install
simonf999
PostPosted: Fri Jul 21, 2006 10:03 pm    Post subject: Map refuses to install Reply with quote
This is a continuation of earlier posting.
I have now downloaded both the installer & zipped versions of the France Plus map.
Just in case there is a problem with the card, I have tried to install to the hard drive, but both versions refuse to install, with the error message 'Disk Access Problem'. I have also tried on a different computer with the same error message.
I can't believe I'm the only one this problem! I am also trying to get a solution from Tomtom support.
Any one with a solution?
Thanks, Simon.
alix776
PostPosted: Fri Jul 21, 2006 10:20 pm    Post subject: Reply with quote
is the sd card set to write protect (little sliding tab on the side of the sd card)
device Lumia 950 xl
simonf999
PostPosted: Fri Jul 21, 2006 10:26 pm    Post subject: Reply with quote
No the SD card isn't locked. The card works perfectly well in the TT1.
The issue for me at the moment is that the map won't even install to the hard drive never mind the SD card.
Simon
alix776
PostPosted: Fri Jul 21, 2006 10:29 pm    Post subject: Reply with quote
you you can dowload the map from tomtom to the pc's hard drive
device Lumia 950 xl
simonf999
PostPosted: Fri Jul 21, 2006 11:23 pm    Post subject: Reply with quote
The download from Tomtom is an installation program not a folder with the map in.
It's the downloaded setup program from Tomtom that won't even install the map to the hard drive, let alone the Tomtom One.
Simon
simonf999
PostPosted: Sat Jul 22, 2006 2:23 pm    Post subject: Reply with quote
I have solved the problem.
I installed Tomtom Home on my computer, downloaded the map (again!) via TT Home and installed via TT Home on to the 1GB SD card.
The card is now fully functional.
22.094 (25 Sep 24)
