welshgasman Regular Visitor
Posted: Thu Jul 20, 2006 7:05 pm Post subject: |
The easy way is to use a TransFlash to SD card addaptor, have a look at Maplins code number A71FC, but if you need to purchase a new card they sell Trans Flash supplied complete with an addaptor (thats how I got mine), simply insert the Transflash card into the addaptor, then insert the assembly into the SD slot of your new card reader - Mike |
Anita Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/animal_duck.jpg)
Posted: Thu Jul 20, 2006 8:39 pm Post subject: |
This is a small reader which is only for micro SD cards, and doesn't need an adaptor.
http://www.7dayshop.com/catalog/product_info.php?cPath=777_5&products_id=101210
It's on offer at £2.99, but delivery's £3.95. However, I never have any trouble finding loads of other bargains in 7dayshop's specials and clearance lines to make the P&P charge worthwhile. :D _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
wherethehellarewe Occasional Visitor
![](modules/Forums/images/avatars/1684338564487eb8080064.gif)
Posted: Fri Jul 21, 2006 9:56 am Post subject: |
Anita,
Are you out of the kitchen again ? :D _________________ Ignorance is no excuse ! |
Posted: Fri Jul 21, 2006 6:52 pm Post subject: |
wherethehellarewe wrote: | Anita,
Are you out of the kitchen again ? :D |
Had to come out of the kitchen to go to work, but I'm on my way back there now. ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ Anita
UK map 1130.12368
Posted: Sat Jul 22, 2006 11:54 am Post subject: |
That looks like it will do the job. I have plenty of readers, just not for Trans flash. The one I bought made no mention of adapter, just that it would work with them.
It is very much like the other link posted.
Thanks.
mikealder wrote: | The easy way is to use a TransFlash to SD card addaptor, have a look at Maplins code number A71FC, but if you need to purchase a new card they sell Trans Flash supplied complete with an addaptor (thats how I got mine), simply insert the Transflash card into the addaptor, then insert the assembly into the SD slot of your new card reader - Mike |
dicko-1 Occasional Visitor
Joined: Feb 12, 2006 Posts: 20 Location: North Staffs
Posted: Sat Jul 22, 2006 10:26 pm Post subject: |
i brought micro sd card from 7day and it came with a sd adapter ?
have also brought a bigger memory micro sd card and tried to copy original data on to it but you cannot do this as gamin have put some sort of security on it to stop you from copying it?
i think you can get a bigger memory card with mapping on it from gamin but it costs you |
Posted: Sat Jul 22, 2006 10:47 pm Post subject: |
You cannot copy the card on to a larger one it is Secure and locked, but if you need a card to insert into one of the newer i3 devices then a purchased card will work for POI/ Voice files etc. (the maps are contained within the device), therefore the slot is vacant for expansion/ customisation related files once equipped with a card - Mike |
Posted: Sun Jul 23, 2006 11:36 am Post subject: |
Got the adapter from Maplins, and it works fine.
Now for some voices. :-) |
Posted: Sun Jul 23, 2006 4:31 pm Post subject: |
Curious now,
I backed up the card to my laptop, then followed the instructions to change the voices. Loaded back onto the card OK.
I currently only have that card, and it is so small I almost lost it just going to Maplins.
Surely if I bought a new card for this reason, I could restore all the files from my laptop onto the new card and use this?. The fact that it would likely be larger should be immaterial.?
TIA
mikealder wrote: | You cannot copy the card on to a larger one it is Secure and locked, but if you need a card to insert into one of the newer i3 devices then a purchased card will work for POI/ Voice files etc. (the maps are contained within the device), therefore the slot is vacant for expansion/ customisation related files once equipped with a card - Mike |
Posted: Sun Jul 23, 2006 6:19 pm Post subject: |
The newer i3 units have a vacant transflash slot which can be used, the earlier units had the maps loaded onto the card supplied with the device, you cannot copy the supplied card as it doesn't work.
Adding the card to a newer i3 gives you more data storage options, there are loads of posts about this within the Garmin i3/ Street Pilot forum -
I hope this answers you question - Mike |
chapsworth Regular Visitor
Joined: 02/09/2003 17:48:57 Posts: 75 Location: United Kingdom
Posted: Sun Jul 23, 2006 8:11 pm Post subject: |
My i3 came with the maps on the card. I've just copied that to my PC. From the comments so far does this I can't copy it to, say, a 512MB card?
Simon |
Posted: Sun Jul 23, 2006 8:18 pm Post subject: |
chapsworth wrote: | My i3 came with the maps on the card. I've just copied that to my PC. From the comments so far does this I can't copy it to, say, a 512MB card?
Simon | Give it a try, you will find it simply doesn't work - been there got the tee shirt so to speak, if the upgrade from vs7 to vs8 maps were simply a download and re-write to the card we wouldn't have had to send the transflash card back to Garmin to be upgraded (free of charge I might add) - Mike |
Posted: Mon Jul 24, 2006 8:12 pm Post subject: |
Examining my card I have
Folder Voice with multiple vpm files in it.
Folder Poi with file Poi.gpi in it
Files gmapsupp.img and gmapsupp.unl
So do I have a new i3 or not. Bought about May this year.
TIA
mikealder wrote: | chapsworth wrote: | My i3 came with the maps on the card. I've just copied that to my PC. From the comments so far does this I can't copy it to, say, a 512MB card?
