Pocket GPS World :: View topic - C510e
C510e
paulr99
PostPosted: Thu Jul 13, 2006 11:38 pm    Post subject: C510e Reply with quote
Looking very closely at one of these.
Has anybody tried and succeded in uploading the speedcamera database - I know you get mio's database free for a year but I'm thinking ahead!
thanks in advance
Paul
Peasemold
PostPosted: Fri Jul 14, 2006 12:52 pm    Post subject: Re: C510e Reply with quote
thanks in advance
Paul
Yes - you need to install the Miosync application off the second DVD (the map one) and then register at the Mio website. You then need to enter these settings in to Miosync and then synchronise. It seemed to work ok when I did it.
Peasemold
TheInspector
PostPosted: Fri Jul 14, 2006 5:07 pm    Post subject: Reply with quote
Nope - still can't get it to work. It throws up a number of different error messages. Mio support don't reply to emails.
Sallyann
PostPosted: Fri Jul 14, 2006 7:57 pm    Post subject: Reply with quote
Are you using the latest version of MioSync? v1.2 is available on the website.
Sal
TheInspector
PostPosted: Fri Jul 14, 2006 8:18 pm    Post subject: Reply with quote
Yes Sal,
I've downloaded that. Tried it. Uninstalled it. Downloaded it again. Tried it again. Tried the version on the disc. Nothing.
rondun
PostPosted: Mon Jul 17, 2006 11:37 am    Post subject: Re: C510e Reply with quote
thanks in advance
Paul
Thats what I'd like to know too - is the C510e / 710 compatible with the pocket gpsworld database when the 1 year is up.
Anybody know much does the Mio speed camera database cost for a year?
On another note, how often do they update the maps for these (this will be my first satnav) and how much do the updates cost?
And (finally!) can you synchronise your mobile phonebook directly with the c510e (without using Outlook?)
Thanks!
lowie
PostPosted: Mon Jul 17, 2006 1:44 pm    Post subject: Reply with quote
When I get a chance this week i will transfer the speedcamera database from my c710 and see what format it is in. It is woefully out of date on some of the locations. I had deleted the database at the weekend and downloaded via the sync progem only to find it has cameras that were taken off the M6 2 years ago (tested this morning) and Mio support is a total waste of space.
If it is in a database format I will see if I can use a database from pocketgps world to replace it with. (yes I subscribe to the PGPSW camera database too)
Will let you know unless someone else has already tried. :D
Sallyann
PostPosted: Mon Jul 17, 2006 2:22 pm    Post subject: Re: C510e Reply with quote
Paul[/quote]
Thanks![/quote]
According to this link:
http://www.poihandler.com/index.asp
POI Handler is compatible with MioMap 3
and I believe that the PocketGPSWorld camaera database is comptible with POI Handler. But as I'm a beginner here you'd better get confirmation from someone more experienced.
The degree of integration between the C710 and your phone depends on the phone type (just like other units). You'd have to try it with your phone to be sure.
Sal
lowie
PostPosted: Mon Jul 17, 2006 4:01 pm    Post subject: Reply with quote
SallyAnn i think you will find that poihandler.com is just a site to download poi's from. It isn't a software program. The POI's they produce are indeed compatible with miomap 3 but there isn't a 3rd party program as far as i know that can be used on the c510/710. I did email navigating.de about a program call poiwarner and they advised that it wasn't supporting miomap3 at the moment. But who knows in the future. Can but hope as it would be nice to use pocketgpsworlds camera database which is a 1000 percent better than the current Mio Sync database. Crying or Very sad
Sallyann
PostPosted: Mon Jul 17, 2006 5:38 pm    Post subject: Reply with quote
Understood about POI Warner, but do you NEED it?. The C710 seems to be quite OK about telling you about POI's, so if you could convert the pocketgpsworld camera database into the C710's format, wouldn't that be good enough?
I have just been looking inside the POI file from my C701, and it seems a fairly simple format. Interestingly enough, a number of the camera sites it contains are labelled "POI-Warner RECORD" followed by a date, so we know where it has come from!
I did download one of the free POI files from POIhandler, in what was alleged to be Mitac format, but it is in fact only standard CSV format so not exactly useful.
Sal
rondun
PostPosted: Tue Jul 18, 2006 1:28 pm    Post subject: Reply with quote
Thanks guys - guess we'll just have to wait and see.
BTW if anyone knows how a Nolia 6230 will work with the 510 as far as synchronising phonebooks goes, I'd appreciate it
CeeJay
PostPosted: Thu Jul 20, 2006 1:50 am    Post subject: Reply with quote
Hi rondun.
I'm using a 6230i with a 710 and the phonebook doesn't transfer to the unit, or at least I haven't got mine to yet!
You can add your own contacts which are saved in the unit itself. Minor nuisance factor.
So far I've only put in the number's I'm likely to dial on the road. Haven't had time to put the other 240 odd numbers in yet.
Something to do on a rainy day I suppose. Laughing
CeeJay.
Sallyann
PostPosted: Thu Jul 20, 2006 11:28 am    Post subject: Reply with quote
I've started a new topic on replacing the camera database, here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=43218
Sal
22.064 (26 Jun 24)
