Pocket GPS World :: View topic - GPS device not found? TTN5 & XDA2
Mattyboy101
PostPosted: Sun Jul 16, 2006 3:50 pm    Post subject: GPS device not found? TTN5 & XDA2 Reply with quote
Hi there,
I hard wired my GPS in last week, with the receiver under the dash, the cigarette lighter power source hidden behind the dash (I got a second cigarette lighter then connected it all up and electrical tape wrapped it together) and the data end comes through the ash tray to my XDA in a Brodit mount. Hope that makes sense!!
The cable came from Morpeth mobiles, and is a Y type device that charges and passes GPS data.
For some reason now, it says no GPS device in TomTom - It used to work and have changed nothing. It still charges, so is all plugged in, and the GPS device works if I try it in my old Arkon powered mount - so i'm a bit baffled!!
Any suggestions? Sad
PostPosted: Mon Jul 17, 2006 7:23 am    Post subject: Reply with quote
When you say the GPS unit works with the Arkon powered mount, how are you connectings it? it is in anyway different to the cable that is employed with the unit in the Brodit holder. Mike
Mattyboy101
PostPosted: Mon Jul 17, 2006 3:07 pm    Post subject: Reply with quote
The GPS is a Haicom 204 (if I remember correctly), and it connects to the Arkon with an adaptor that changes the PS/2 lead to an RJ11 for the mount.
The Y cable I got has a PS/2 end on it so it connects directly.
I kept all settings the same and it used to work fine - I guess there must be a problem with the adaptor itself Confused
bryson
PostPosted: Mon Jul 17, 2006 11:55 pm    Post subject: Reply with quote
hi,
have you got your 'receive incoming beams' unticked?
Cheers,
Bryson
Mattyboy101
PostPosted: Tue Jul 18, 2006 12:32 am    Post subject: Reply with quote
Do I need it unticked? I left it in the office, will have a play tomorrow!
I hope it is something simple like that!! Embarassed
Mattyboy101
PostPosted: Tue Jul 18, 2006 9:38 am    Post subject: Reply with quote
The box was already unticked, however it has decided to work now Confused
bryson
PostPosted: Tue Jul 18, 2006 10:09 am    Post subject: Reply with quote
Ah, well i hope its stable for you now! Maybe its just a moody port on the xda?!
I take it you have gone into the gps set up, and selected othere wired gps and gone through the set up that way (ie selecting the port etc?)
Cheers,
Bryson
Mattyboy101
PostPosted: Wed Jul 19, 2006 8:24 pm    Post subject: Reply with quote
Yea its an other wired GPS, 4800 baud rate on Com1.
Seems to work fine, just having problems keeping a good signal now, although I have wired it behind the dash!!
Mattyboy101
PostPosted: Sun Jul 30, 2006 6:03 pm    Post subject: Reply with quote
Right, the problem I have now is it keeps losing the maps, it will lose all roads other than the one you are on, and if you restart it will say none are recognised.
I've ordered a new SD card in case the old one is playing up! Confused
lostinuk
PostPosted: Tue Aug 01, 2006 8:21 am    Post subject: Reply with quote
Dont know if this is relevant, but when I used to use my road angel as the GPS for my Ipaq running TT N2,3or5, if the power cables that suplied the power/gps signal ran over the top or underneath the road angel, then I would lose signal or get constantly changing map data.
Just a thought!
Iphone 7 running IOS 11.1.2
CamerAlert
Tom Tom W Europe
Tom Tom US-Canada
Now using Waze as primary GPS.
22.071 (03 Jul 24)
