Pocket GPS World :: View topic - SPV M5000/TomTom Help!!
Burnhard
PostPosted: Tue Jul 18, 2006 2:23 pm    Post subject: SPV M5000/TomTom Help!! Reply with quote
OOPS no subject Sorry all
SPV M5000 Help!!
My Ipaq has packed up. I have been issued with a new M5000 which I need to setup using TomTom software version 5 and Bluetooth GPS reciever. I have been able to install the software using the Latest updates from TT. But as the phone/PDA is not supported by them they will not assist me with the Issue that I have. I have perchased the London map from them and that once downloaded TT can see it. But the CDs with my other maps on will not load I get a "this program has caused an error and must shut down" message. So I was told I could copy the maps to the PDA and it will find them. This has proved to be not the case for me. Also the PDA partners with the TT GPS unit but TT does not see it.
How do I get TT to see my Maps?
How do I get TT to see my GPS receiver?
Regards
Burnhard
Burnhard
PostPosted: Tue Jul 18, 2006 4:17 pm    Post subject: Fixed TT GPS receiver issue Reply with quote
Hello All
I have managed to fix the Hardware problem but still need assistance on the map issue. Exclamation Embarassed
I could copy small map to the same location as the London map as this is on the PDA memory, but there is not and never will be enough memory there to use the full British maps 210Mb!!
Please help Crying or Very sad Crying or Very sad Crying or Very sad
moles1
PostPosted: Tue Jul 18, 2006 5:20 pm    Post subject: Reply with quote
Sorry cant help you but im having the same trouble except i cant even load the application on. When you install the cd and select either maps or the application it just crashes and gives an error report. How did you manage to install the application?.
Burnhard
PostPosted: Tue Jul 18, 2006 6:11 pm    Post subject: Installed TT5 Reply with quote
Hello there I went to TT and downloaded the latest update update and attempted to install it and it worked. I did copy one down yesterday that did not work. Maybe there is a new version out today???. I then installed a map of london that I purchased from TT and I can now see that. but still cannot see the GB Maps GRRRRRRRRRRR
So your guess is as good as mine at the moment
I found this link to a similar problem with the same phone diferent name though (K-Jam? )
http://www.howardforums.com/showthread.php...806#post6166806
Also you need to turn the phone function on on your PDA, in flight mode it will not see the GPS receiver!!!! :P
Seeyalata
Burnhard
PostPosted: Tue Jul 18, 2006 6:12 pm    Post subject: Reply with quote
Firstly to get the application to load download the latest version of TomTom Navigator from the TomTom site (version 5,21) this will install from the PC to the M5000 via Active Sync. Although I will also add you should check THIS as it is a common fault.
For the maps, I would firstly sugest you copy the map you require to the hard drive of the PC, then copy it to the SD card, preferably using a card reader as its so much faster - Mike
Burnhard
PostPosted: Tue Jul 18, 2006 6:17 pm    Post subject: OOPS Reply with quote
Tried that link but it gave me an error try this link then you will have to look for that link on that page as you will be able to then click on the link and it will take you to the correct page!!!1 Embarassed Embarassed
http://www.modaco.com/TomTom_5_on_SPV_M5000_GPS_problem-t238188.html
Hope this all makes more sense to you than it does to me Laughing
Burnhard
PostPosted: Tue Jul 18, 2006 6:26 pm    Post subject: MAps Reply with quote
Hello Mike
I have tried this but When I go into the change map settings in TT I get only the one map showing up. So TT is not seeing it and I was wondering if there is a particular location or Name for the Map directory. I have used one suggested to me which was Great_Britain-Map in the route of my SD card bu this has not worked at all?? Crying or Very sad Crying or Very sad Crying or Very sad
PostPosted: Tue Jul 18, 2006 6:41 pm    Post subject: Reply with quote
The location of the Map folder should be in the root of the memory card i.e. the highest level in the tree when viewed, your folder name should be the same as that, the installer created on the PC - Mike
Burnhard
PostPosted: Tue Jul 18, 2006 6:58 pm    Post subject: Reply with quote
Hello Mike
I cannot do install them to my hard drive as you can see from a previous post.
"I have perchased the London map from them and that once downloaded TT can see it. But the CDs with my other maps on will not load I get a "this program has caused an error and must shut down" message. So I was told I could copy the maps to the PDA and it will find them."
That is why I was hoping someone could just look on their PDA and see where it has been put and what the directory name is :P
Also if there is some way of making TT point to that folder Question I am sure there someone out there who can explain that to me Laughing That would help
Seeyalata
Burnhard
PostPosted: Tue Jul 18, 2006 7:18 pm    Post subject: Reply with quote
What is the file size of the map you are trying to install? - it could be a Plus map rather than just the standard one? - Mike
Burnhard
PostPosted: Wed Jul 19, 2006 9:27 am    Post subject: Reply with quote
Its 210 Mb and it comes off one ot the CD's that came with the original Package
PostPosted: Wed Jul 19, 2006 5:51 pm    Post subject: Reply with quote
In that case it is indeed a "plus" map the root folder is named
Great_Britain_Plus-Map I would be tempted to contact TomTom support with respect to the disk being damaged etc if its refusing to load correctly, perhaps they could help - Mike
Burnhard
PostPosted: Thu Jul 20, 2006 9:04 am    Post subject: Reply with quote
Hello Mike
Firstly thanks for the help. Wink What I have done to resolve the issue is to take the SD card and insert it into the old IPAQ and install it all on there then take the SD card and re-insert it in the M5000. This has worked fine so if there is anyone else out there who has issues regarding the M5000 they can check this link out for assistance.
What I have also done is copied the contents of my SD card to my hard drive so if any issues arrive I will have a copy on hand to copy back to my SD card Laughing
Thanks all who have helped regarding this issue and I will be watching this link so if anyone has any more issues thy just need to update the posts and I will get an email :P :P :P
Seeyalata
Burnhard
22.071 (03 Jul 24)
