Pocket GPS World :: View topic - dont know how to down load file & unzipped, pls advice
asiaocean05
PostPosted: Mon Jul 17, 2006 9:43 am    Post subject: dont know how to down load file & unzipped, pls advice Reply with quote
i am very new with com, has never down load or use zipped files b4, just have no idea how to do it , i print the instruction out & follow it, still go no where as i found only .BMP cant find .OV2[singlefilecamera for tomtomone
and i cant unzipped file & copy as well. pls help. thanks Sad Question
PostPosted: Mon Jul 17, 2006 10:37 am    Post subject: Reply with quote
Did you use the Instructions found here?
If you found the BMP File, you must have been able to Unzip the Download.;)
If you are using a PC with XP, DoubleClick the Downloaded Zip File, and the default UnZip Program should Open and display the contents of the Zip File. It might be WinZip or XP's own UnZip program.
There should be 5 Files there, 2 Text Files, a Help File, the OV2 and BMP Files.
You then need to Extract the OV2 and BMP Files to your PC. Remember where.
Then in Windows Explorer, Copy/Paste these 2 Files to the Map Folder on your ONE.
You will need to connect the ONE to the PC for this last step.Smile
23.054 (28 May 25)
