Pocket GPS World :: View topic - Loading onto Palm OS
alix776
PostPosted: Fri Jul 14, 2006 10:01 pm    Post subject: Reply with quote
ok that rules that out try redownloading the database unzip the files and try coping the .ov2 and bmp to the card again.
device Lumia 950 xl
dd_uk
PostPosted: Fri Jul 14, 2006 10:05 pm    Post subject: Reply with quote
I am begining to believe that:
a) Nobody has ever done this
b) It isn't possible
c) I've wasted my money AGAIN
alix776
PostPosted: Fri Jul 14, 2006 10:08 pm    Post subject: Reply with quote
no you havent it does work please try redownloading the database as the first time you downloaded may have been corrupt
device Lumia 950 xl
PostPosted: Fri Jul 14, 2006 10:20 pm    Post subject: Reply with quote
As Alix says, TomTom Navigator works the same on all platforms, and loads of other people would have complained by now if it didn't work.
Can I suggest you try another POI from another website (try
http://www.tomtomfree.com/singlePOIfile.htm) and see if you have better luck with that.
It might be the way you are un-zipping the archive? Are you downloading on a PC or a Mac?
dd_uk
PostPosted: Fri Jul 14, 2006 10:54 pm    Post subject: Reply with quote
Downloaded the camera files again with no luck.
Downloaded a POI from that site Andy also didn't work. I'm using a PC.
What is making me wonder is the lack of a detailed Q&A for Palm there are extensive ones for Pocket PC. I cannot believe that I am the first person to want to load the database onto a Palm.
The TomTom site only has instructions for a Go version
alix776
PostPosted: Fri Jul 14, 2006 10:57 pm    Post subject: Reply with quote
if you use an sdcard reader then the instructions are the same
for the 5th time adding POI's to tomtom is the same across all platforms the faq for go or for pocket pc relate the same method there is no special way if your using a palm
using the sd card reader method its the same
device Lumia 950 xl
alix776
PostPosted: Fri Jul 14, 2006 11:00 pm    Post subject: Reply with quote
dd could you please write down what method you are using please step by step as you have most of us flumxt
device Lumia 950 xl
PostPosted: Fri Jul 14, 2006 11:08 pm    Post subject: Reply with quote
When you view the memory card how many map folders are there?
I have known people place the POI into the map folder then not selecting the correct ACTIVE map when more than one map is present.
For example if you have both the GB map and the GB PLUS map loaded to the card which one have you loaded the POI to, then is this the active map (selectable in preferences) - Mike
dd_uk
PostPosted: Fri Jul 14, 2006 11:39 pm    Post subject: Reply with quote
RIGHT you want it stage by stage
downloaded the zip file (pgpsw-speed-cams.zip) to my PC
Extracted the files to a totally separate directory
Copied all the OV2 and bmp files to the GB map folder on the SD card
Started Navigator
Went to manage POI where I have the following choices:
Add POI
This adds extra POI's to a catagory
Add POI catagory
This adds a catagory but the I can't add the POI's under the above
Warn when near POI
This displays the various catagagories
Enable/Disable POI's
If you look at
http://www.tomtom.com/support/index.php?Language=1&query=ov2+files&FID=2010
which deals with TomTom Go it says 'Finally, to enable POI's in your TomTom GO select them in your POI categories. They now are displayed on your GO screen in both 3D maps and 2D maps.'
I do not have a POI catagories I have those shown above
PostPosted: Fri Jul 14, 2006 11:45 pm    Post subject: Reply with quote
Use the "Warn when near POI" option and configure the warnings as I stated earlier, you will have to scroll though the list of inbuilt POI to get to the Pocketgps ones - Mike
alix776
PostPosted: Fri Jul 14, 2006 11:46 pm    Post subject: Reply with quote
you need warn when ner poi scroll down the list and you should see the pocketgps speed camera files highlight one off these set the distance you want then add a sound from the preinstalled sounds
to see them on the map select enable poi and tick the boxes next to pocketgps files then select done inthe browse map part of tt navigator you should now see the cameras on your map and aslo get warnings
device Lumia 950 xl
dd_uk
PostPosted: Fri Jul 14, 2006 11:57 pm    Post subject: Reply with quote
The Pocket gps files do not appear either with 'enable' or 'warn when near'
Now what????????????????????????????????????[/b]
alix776
PostPosted: Sat Jul 15, 2006 12:03 am    Post subject: Reply with quote
where do they not appear in the list or on the map
device Lumia 950 xl
dd_uk
PostPosted: Sat Jul 15, 2006 12:05 am    Post subject: Reply with quote
They do not appear ANYWHERE
alix776
PostPosted: Sat Jul 15, 2006 12:10 am    Post subject: Reply with quote
could please list the folders in the root of the sd card it might give us a clue as to whats happening.
the root of the s car is the first level you see
device Lumia 950 xl
Page 2 of 3
22.124 (26 Dec 24)
