Pocket GPS World :: View topic - Holux 236 works with TomTom but not GPS Viewer
spywgc
PostPosted: Fri Jul 14, 2006 6:02 pm    Post subject: Holux 236 works with TomTom but not GPS Viewer Reply with quote
Just got a Holux 236 which works fine with TomTom on my ipaq 2210.
When I attempt to use the Holux GPS Viewer I get open failed message on port 8. Attempting to open port directly gives 'can not open com port' msg.
Can anyone please help?
alix776
PostPosted: Fri Jul 14, 2006 6:22 pm    Post subject: Reply with quote
do a soft reset and only run one gps app at a time
device Lumia 950 xl
spywgc
PostPosted: Fri Jul 14, 2006 6:27 pm    Post subject: Reply with quote
I have done many soft resets and am not connected to any other apps...
I switch ipaq on, turn on BT, run GPS Viewer and scan all ports & no success.
I can pair the device no problem. Also noticed that GPS in Programs\settings is no longer there....
alix776
PostPosted: Fri Jul 14, 2006 7:06 pm    Post subject: Reply with quote
have you tried connecting to the gps with out it being paired
device Lumia 950 xl
spywgc
PostPosted: Fri Jul 14, 2006 8:13 pm    Post subject: Reply with quote
Yes, also tried to connect to old gr230 but had same problems. TomTom shows GPS driver as V1.20 if this helps....
mgibbs
PostPosted: Sat Jul 15, 2006 9:00 pm    Post subject: Reply with quote
I have exactly the same problem with my combination of TomTom 5/GPS Viewer and 2210
Mark
iPaq 2210, TomTom 5.21, Holux CF100 gps cradle, Holux GPSlim 236, 512Mb CF card, 1Gb SD card.
alix776
PostPosted: Sat Jul 15, 2006 9:15 pm    Post subject: Reply with quote
to be honest you dont really need gps veiwer installed if your using tomtom unless you want to flick the receiver into sirf mode but then tomtom will not see the receiver
device Lumia 950 xl
spywgc
PostPosted: Sat Jul 15, 2006 9:46 pm    Post subject: Reply with quote
Yep I have lived without it on my old GR230 but would still be nice to have it working in case I wanted to use with another app.
Is it correct that I no longer have a GPS program in Programs\Settings?
Thanks again
Mikeact
PostPosted: Tue Jul 18, 2006 3:05 pm    Post subject: Reply with quote
Mine doesn't work either...not that it's a big deal, but it did when I first installed it some time back.
meestermartinho
PostPosted: Wed Jul 19, 2006 12:38 pm    Post subject: Re: Holux 236 works with TomTom but not GPS Viewer Reply with quote
Gps viewer is known to cause issues with tomtom as well I would uninstall it.
MarcUK
PostPosted: Thu Jul 20, 2006 8:35 am    Post subject: Reply with quote
I recieved my 236 last night and tried the viewer, all worked fine. The manual states that you should set the port to 38400 bps - Didn't work, set it to 4800 bps and worked a treat.
Marc
spywgc
PostPosted: Fri Jul 21, 2006 11:56 am    Post subject: Reply with quote
I've tried all baud rates, spoke with Holux UK who to be honest could not offer much more than to suggest updating TomTom to latest version which I'm reluctant to do given that it all works well.
Quantum
PostPosted: Sun Jul 30, 2006 6:05 pm    Post subject: Reply with quote
Works fine on my hx4700 with Com8/38400.
I think VisualGPSce is better tho. And SiRFTech to change the settings on the 236.
For accuracy though, the new Nemerix chipset pods are better. (i.Trek M5)
22.064 (26 Jun 24)
