Pocket GPS World :: View topic - 32 channels better than 20?
OM3
PostPosted: Thu Jul 13, 2006 12:57 pm    Post subject: 32 channels better than 20? Reply with quote
I've seen GPS receiver that have 32 channels.
Are these significantly better than 20 channel units?
Thanks.
OM
PostPosted: Thu Jul 13, 2006 3:46 pm    Post subject: Reply with quote
As there are only 24 satellites orbiting the planet that are used for GPS positional data in use at any single time, also you can only theoretically see a maximum of 12 satellites from a ground based position at any single time, so there is little point in having multi channel capable receivers that have more channels than there are satellites in orbit..
In practice the extra channels on the 20 or 32 chnl devices will be used as the receiver will pick up multiple path signals from the same satellite (reflections off buildings etc) - the issue of which is best - there are far more important factors to consider, sensitivity etc.
Personally if its not equipped with a SiRF-III chipset I wouldn’t touch it - Mike
7andy
PostPosted: Fri Jul 14, 2006 1:28 pm    Post subject: Reply with quote
Don't forget, in the near future (c 2008) we shall start to see Gallileo (the European GPS system) coming online, so theoretically, we could see more than twelve satellites.
Cheers, 7&Y
neil01
PostPosted: Fri Jul 14, 2006 1:31 pm    Post subject: Reply with quote
7andy wrote:
Don't forget, in the near future (c 2008) we shall start to see Gallileo (the European GPS system) coming online, so theoretically, we could see more than twelve satellites...
But will the current hardware be compatible?
7andy
PostPosted: Sat Jul 15, 2006 10:18 am    Post subject: Reply with quote
I understand that's the plan :D In fact it's so compatible, that the Americans demanded that they should be able to turn it off should they wish.
Cheers, 7&Y
PS Since when did the Americans own Space??
portman
PostPosted: Thu Jul 20, 2006 4:27 pm    Post subject: Reply with quote
I've got a Qstarz BT-880 (32channel)bought off ebay about 6/8 months ago and its very good, works indoors and out, instant hot start and 30-40 secs cold start, about half the time of my Garmin i3.
22.064 (26 Jun 24)
