Pocket GPS World :: View topic - Dashboard Disk
Dashboard Disk
carphead
PostPosted: Tue Jul 11, 2006 10:29 pm    Post subject: Dashboard Disk Reply with quote
Anybody know where I can get a dashboard disk (small plastic disk which sticks to the dashboard but with a lip round it) to fit the x10 mount?
I've got the perfect cubby hole in the dash of my Mazda 6 but can't find a disk to fit under one. I've found one with a Arkon mount but don't want the complete system just the disk.
oldfogy
PostPosted: Tue Jul 11, 2006 11:46 pm    Post subject: Reply with quote
TomTom do supply one, but I think it comes as part of a kit.
You could also try looking at the "Medion Disc Mount" and see if they do one separately as I think it's also the same size.
Just out of curiosity, where on the Mazda 6 are you thinking of?
I've got the 626 and can't see anywhere except a window mount that is suitable. (Unfortunately) Thanks.
(If it ain't broke, I can soon fix it)
carphead
PostPosted: Wed Jul 12, 2006 1:00 am    Post subject: Reply with quote
Thanks I'll try those sources.
The 6 has a pocket on the top of the dash. It's where the Factory Sat Nav fits. It can fit the x10 mount fine but not fully assembled. When I can source another TT mount I'm going to try and mod it but until then I'm happy having to assemble it each time.
Thats why I need the disc.
oldfogy
PostPosted: Wed Jul 12, 2006 1:39 am    Post subject: Reply with quote
Obviously a different layout to mine (626, 1999).
I was thinking about putting a disc mount in the "tray above the glove box", could've just thrown a book or cloth on-top of it when not being used to hide it, (because it's no good for anything else) but it's a little bit too far away for my liking.
Good luck and thanks anyway.
LesP2008
PostPosted: Wed Jul 12, 2006 12:55 pm    Post subject: Reply with quote
On ebay a seller called lindens sells both types of these discs i have had about three off him over the last two years, he's reliable.
HappyTrucker
PostPosted: Wed Jul 12, 2006 8:09 pm    Post subject: Reply with quote
Here's a link to one of Lindens discs. He does packs of 3,5 and 10 too. Usually with you within 24 hours or so.
http://cgi.ebay.co.uk/TomTom-GO510-GO710-GO910-Dashboard-Suction-Plate-Tom_W0QQitemZ9743876384QQihZ008QQcategoryZ75327QQcmdZViewItem
carphead
PostPosted: Wed Jul 12, 2006 10:05 pm    Post subject: Reply with quote
Thank you all. I search on Ebay but couldn't find anything.
Thanks a lot all.
PostPosted: Wed Jul 12, 2006 11:42 pm    Post subject: Reply with quote
Just click HERE and you will be taken to the page on Ebay that Happy Trucker posted earlier, it works - Mike
carphead
PostPosted: Thu Jul 13, 2006 4:00 pm    Post subject: Reply with quote
I think I must of had my idiot cartridge plugged in yesterday.
What I should of said is that I'd searched on Ebay before posting here to start with.
Thanks to you guys I've brought a set of 3 from lindens.
Sorry having a bad day yesterday.
Thanks all.
javey
PostPosted: Tue Jul 25, 2006 5:57 pm    Post subject: Mazda 6 fitting Reply with quote
How did you get on with the disk mounting?
I have a Mazda 6 and have been looking at ways of permanently mounting my TomTom 910 in the dashboard cubby hole.
Did you stick the disk to the carpet like liner in the dash or did you cut a hole in the liner?
I am going to rip the dashboard apart this weekend to hardwire the TomTom cables directly into the cubby hole. They look really unsightly dangling in front of the radio !!
If you are interested, there is a superb addon for the Mazda 6 radio which allows you to pipe the MP3 output from the 910 directly into the stereo. I am just toying with ordering one of these.
Best Regards
Pedro2NR
PostPosted: Thu Aug 10, 2006 12:12 am    Post subject: Reply with quote
Here is a picture of my car with the dashboard disk.
fatmanscoop
PostPosted: Sat Aug 12, 2006 11:49 am    Post subject: Reply with quote
so were is the pic Laughing
Garmin xt mobile
Nokia N96
Liverpool F.C rocks
Pedro2NR
PostPosted: Sat Aug 12, 2006 8:45 pm    Post subject: Reply with quote
Laughing Out Loud!
Bad wording on my part.
carphead
PostPosted: Wed Aug 16, 2006 3:25 pm    Post subject: Reply with quote
Javey - Sorry I hadn't checked back in a while.
I already had a AuxMod fitted to the Stereo for my Mazda 6 (brilliant piece of kit, well worth the money). So to that I fitted a dual 3.5 stereo jack. I've routed one cable to the map pocket and one to the cup holders.
I then cut the cable to the existing Power Socket and re-attached it with a longer lead (it's really tough to get back in otherwise) at the same time I added another two sockets. One runs behind the stereo and into the map pocket. The other power socket goes to the armrest (perfect for a phone). I took out the map pocket when I did the power drilled a small hole in the back and ran the power lead into it.
Whilst I had the map pocket removed I played around with the position of the dashboard disk and found the perfect place on nearest the driver at the back corner. In that position the TT can lay on the lip of the map pocket to stop it wobbling.
If I decide to get the IPOD cable I can hook the TT upto the AuxMod cable .
For the dashboard disk I removed the carpet cut the back corner off it then stuck it down with velco. After a while the carpet decided to ball up so I just took it out. All I have to do when parked is remove the TT stick it in the map pocket and close the top or put it in the glovebox.
I have a small metal cash box mounted in the glove box which was a laptop lock down attachment which runs around some unexpossed body work which I secure my backup mobile phone and Tomtom.
So basically I've got nothing on show when parked up. No GPS mount or power leads all are hidden.
Pedro2NR
PostPosted: Wed Aug 16, 2006 4:03 pm    Post subject: Reply with quote
Please post some pictures!
