carphead Occasional Visitor
Posted: Tue Jul 11, 2006 10:29 pm Post subject: Dashboard Disk |
Anybody know where I can get a dashboard disk (small plastic disk which sticks to the dashboard but with a lip round it) to fit the x10 mount?
I've got the perfect cubby hole in the dash of my Mazda 6 but can't find a disk to fit under one. I've found one with a Arkon mount but don't want the complete system just the disk. |
oldfogy Frequent Visitor
Joined: May 08, 2006 Posts: 252 Location: West Midlands. UK
Posted: Tue Jul 11, 2006 11:46 pm Post subject: |
TomTom do supply one, but I think it comes as part of a kit.
You could also try looking at the "Medion Disc Mount" and see if they do one separately as I think it's also the same size.
Just out of curiosity, where on the Mazda 6 are you thinking of?
I've got the 626 and can't see anywhere except a window mount that is suitable. (Unfortunately) Thanks. _________________ (If it ain't broke, I can soon fix it) |
Posted: Wed Jul 12, 2006 1:00 am Post subject: |
Thanks I'll try those sources.
The 6 has a pocket on the top of the dash. It's where the Factory Sat Nav fits. It can fit the x10 mount fine but not fully assembled. When I can source another TT mount I'm going to try and mod it but until then I'm happy having to assemble it each time.
Thats why I need the disc. |
Posted: Wed Jul 12, 2006 1:39 am Post subject: |
Obviously a different layout to mine (626, 1999).
I was thinking about putting a disc mount in the "tray above the glove box", could've just thrown a book or cloth on-top of it when not being used to hide it, (because it's no good for anything else) but it's a little bit too far away for my liking.
Good luck and thanks anyway. _________________ (If it ain't broke, I can soon fix it) |
LesP2008 Lifetime Member
Posted: Wed Jul 12, 2006 12:55 pm Post subject: |
On ebay a seller called lindens sells both types of these discs i have had about three off him over the last two years, he's reliable. |
HappyTrucker Regular Visitor
Posted: Wed Jul 12, 2006 10:05 pm Post subject: |
Thank you all. I search on Ebay but couldn't find anything.
Thanks a lot all. |
Posted: Wed Jul 12, 2006 11:42 pm Post subject: |
carphead wrote: | Thank you all. I search on Ebay but couldn't find anything. | Just click HERE and you will be taken to the page on Ebay that Happy Trucker posted earlier, it works - Mike |
Posted: Thu Jul 13, 2006 4:00 pm Post subject: |
I think I must of had my idiot cartridge plugged in yesterday.
What I should of said is that I'd searched on Ebay before posting here to start with.
Thanks to you guys I've brought a set of 3 from lindens.
Sorry having a bad day yesterday.
Thanks all. |
javey Occasional Visitor
Posted: Tue Jul 25, 2006 5:57 pm Post subject: Mazda 6 fitting |
How did you get on with the disk mounting?
I have a Mazda 6 and have been looking at ways of permanently mounting my TomTom 910 in the dashboard cubby hole.
Did you stick the disk to the carpet like liner in the dash or did you cut a hole in the liner?
I am going to rip the dashboard apart this weekend to hardwire the TomTom cables directly into the cubby hole. They look really unsightly dangling in front of the radio !!
If you are interested, there is a superb addon for the Mazda 6 radio which allows you to pipe the MP3 output from the 910 directly into the stereo. I am just toying with ordering one of these.
Best Regards |
Pedro2NR Regular Visitor
Posted: Thu Aug 10, 2006 12:12 am Post subject: |
Here is a picture of my car with the dashboard disk.
fatmanscoop Regular Visitor
Joined: Jul 07, 2005 Posts: 244 Location: Nottingham...
Posted: Sat Aug 12, 2006 11:49 am Post subject: |
so were is the pic _________________ Garmin xt mobile
Nokia N96
Liverpool F.C rocks |
Posted: Sat Aug 12, 2006 8:45 pm Post subject: |
Bad wording on my part. |
Posted: Wed Aug 16, 2006 3:25 pm Post subject: |
Javey - Sorry I hadn't checked back in a while.
I already had a AuxMod fitted to the Stereo for my Mazda 6 (brilliant piece of kit, well worth the money). So to that I fitted a dual 3.5 stereo jack. I've routed one cable to the map pocket and one to the cup holders.
I then cut the cable to the existing Power Socket and re-attached it with a longer lead (it's really tough to get back in otherwise) at the same time I added another two sockets. One runs behind the stereo and into the map pocket. The other power socket goes to the armrest (perfect for a phone). I took out the map pocket when I did the power drilled a small hole in the back and ran the power lead into it.
Whilst I had the map pocket removed I played around with the position of the dashboard disk and found the perfect place on nearest the driver at the back corner. In that position the TT can lay on the lip of the map pocket to stop it wobbling.
If I decide to get the IPOD cable I can hook the TT upto the AuxMod cable .
For the dashboard disk I removed the carpet cut the back corner off it then stuck it down with velco. After a while the carpet decided to ball up so I just took it out. All I have to do when parked is remove the TT stick it in the map pocket and close the top or put it in the glovebox.
I have a small metal cash box mounted in the glove box which was a laptop lock down attachment which runs around some unexpossed body work which I secure my backup mobile phone and Tomtom.
So basically I've got nothing on show when parked up. No GPS mount or power leads all are hidden. |
Posted: Wed Aug 16, 2006 4:03 pm Post subject: |
Please post some pictures! |
