Pocket GPS World :: View topic - No Valid GPS
No Valid GPS
Ianrweather
PostPosted: Sat Jun 03, 2006 8:43 pm    Post subject: No Valid GPS Reply with quote
I have a Tom Tom One which has worked ok for about 2 Months, lately it is taking longer and longer to lock on to the sats. If I go into the sat screen it will show the bars receiving the signal in grey, but the sats are in a line from the centre to North, it often takes 30 mins to sort itself out.
Pressing reset sometimes works however mostly it returns to Confused the same state.
Any help or advice would be appreciated.
Ian.
999tommo
PostPosted: Sun Jun 04, 2006 12:21 am    Post subject: Reply with quote
Have you upgraded to 5.45 firmware ? This may well help you.
Tommo...
Regularly absent, but still here in spirit !
Ianrweather
PostPosted: Sun Jun 04, 2006 1:02 am    Post subject: Reply with quote
Upgraded today, hope it sorts the problem out, will test it out.
Alexcook97
PostPosted: Mon Jul 10, 2006 6:25 pm    Post subject: Same Problem - No Valid GPS Signal Reply with quote
I am having the same problem - worked fine for 2 months & now can not find signal easily. I have updated to 5.450 but this has not solved the problem.
It can locate sats but struggles to lock on (turn blue)
Any ideas, could it be a hardware problem?
Alex
MELennium
PostPosted: Mon Jul 10, 2006 7:51 pm    Post subject: Reply with quote
I had same problem with a 910, it would find the sats but would not lock on but as it was brand new I got it replaced, the new 910 works fine. So it could be a hardware fault.
TomTom Go 910 (3) v.6.522 Map Western Europe v.650 with useless TMC receiver
Ex. owner TomTom 910 (2) Returned Faulty
Ex. owner TomTom 910 (1) Returned Faulty
Ex. owner TomTom One v.5.420 Map UK v.605
Ex. owner Garmin i3 v.2.7 Map UK V.7
Thewisp
PostPosted: Mon Jul 10, 2006 8:27 pm    Post subject: Reply with quote
Ditto. I had the same problem with my first TT ONE. Took an age to find and lock onto the signal then would lose the satellites at the drop of a hat. Couldn't complete a journey with it so I took it back and had it replaced - new one works a treat. Picks up the signal usually within about 10-15 secs and once locked on i've not known it to lose a fix. It does sound like a common problem which i'm sure Tomtom must be aware of.
