RODTROTTER Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Sat Jul 08, 2006 2:54 pm Post subject: medion gopal 350 and poi warner |
i just got a medion gopal 350 from asda for £149.99 the problems starts when i need to put on speed cams and pois need to buy poi warner so i did got reg code put it in the it said that i need to rereg it so i did then it said i need to rereg it again so i tryed and they would not give me a reg code they said i have had my two code what am i to do ??? is there any other way of putting pois and speed cams on the gopal please help |
alix776 Pocket GPS Moderator
Posted: Sat Jul 08, 2006 3:11 pm Post subject: |
youll need POI warner to get the warnings for the cameras. have you tried emailing poi warner
also have you set up an account on their website try that and see if it acepts the code that way _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Shayward Occasional Visitor
Posted: Sat Jul 08, 2006 8:04 pm Post subject: |
Hi guys im new to this forum
I've got the same problem. I have registered on their site and they sent me an email. However the product id they sent me was different to the one on my pna, so i emailed them back and i'll let you know what the outcome is.
Sean |
frglee Occasional Visitor
Posted: Sat Jul 08, 2006 8:34 pm Post subject: |
I suspect that POI-Warner are going to get more than a few e-mails about this problem. They've told me that there is a problem with the "Medion Software" and they are working on a fix for it.
They did send me a new install program 'GoPal 350 UK setup_arm_en.exe'
and said this would cure the problem but it ain't done so far.
Hopefully, if they are inundated with cries for help they might sort it pretty quick.
Lee. |
Posted: Sat Jul 08, 2006 10:09 pm Post subject: |
frglee
can you send me a copy of that program they sent you and i will c if it works for me |
