pbd Occasional Visitor
Posted: Fri Jul 07, 2006 10:17 pm Post subject: TomTom MDA Vario, controls not working |
Okay, this is a bizarre one. I've used TomTom on both my palm zire and my spv c500 and c600. Now I've got an all in one Vario and thought I could just put in the card. I did and so far so good. Working fine then I tried to select and the control pad doesn't work. I have to select using the slide out keypad and using the arrow keys in there. That cannot be right because in the palm version it has no trouble using the selecter pad and on the c500 and c600 it uses the joy stick with no problem.
Can anyone help? I'm really confused and cannot work out why TomTom wont recognise the pad. It is TT5 mobile post update. Yes I know I can run navigator on this phone like withthe c600 but I won TT5 mobile and didn't want to shell out again. Works fine apart from the selector pad not being recognised nor the touchscreen working.
Thanks in advance. |
Posted: Fri Jul 07, 2006 10:27 pm Post subject: |
The mobile version of TomTom will not support touch screen as smart phones do not have them, the device you now have is a PDA based phone and as such requires TomTom Navigator 5,21 to work correctly, if you have any activations left with your current licence you might be OK - Mike |
lbendlin Pocket GPS Staff
Posted: Fri Jul 07, 2006 10:28 pm Post subject: |
Welcome to the forums.
Nothing bizarre here, you simply use the wrong software. The Vario is a Pocket PC, not a Smartphone. You need to use TomTom Navigator, not TomTom Mobile.
You can download the latest TTN version from www.tomtom.com _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
alix776 Pocket GPS Moderator
you need to download the pocket pc application to the vario as its a classed as a pocket pc not a phone _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
