jobra Occasional Visitor
Posted: Fri Dec 12, 2003 9:53 am Post subject: Pgs blutooth pda 5450 |
Hei
I have at BT-308-Global Bluetooth GPS, and a PDA 5450 win 2003, i use TomTom ver. 2
I can't start the GPS on my PDA, i have a blutoot connection, but can't start the GPS on the PDA.
i can use com0-1-3-6 on the tomtom, i think that i have to use com8.
hav do i do ?
MVH
Johnny Denmark |
MikeB Frequent Visitor
Posted: Fri Dec 12, 2003 1:16 pm Post subject: |
Johnny,
When you configure the GPS in TomTom you should select the "Emtac Wireless GPS" device and set the ComPort to Com8.
You can also select NMEA 4800 and Com8.
You should have paired the GPS with the PDA before you connect to the TomTom application.
If this fails have you managed to connect to the GPS Disgnostic application provided with the receiver? _________________ Mike Barrett |
Posted: Fri Dec 12, 2003 2:00 pm Post subject: |
Hei Mike
I can't thouse com 8, and i think this is the reason that it not working.
i can those com 0 -1 -3 -6.
Regards
Johnny ( denmark)
MikeB wrote: | Johnny,
If this fails have you managed to connect to the GPS Disgnostic application provided with the receiver? |
Darren Frequent Visitor
Posted: Fri Dec 12, 2003 2:17 pm Post subject: |
Have you 'discovered' the Bluetooth GPS in Bluetooth Manager? Doing this adds the COM8 BT Serial Port. The fact that you're not seeing this suggest you have not done this? _________________ Darren Griffin |
Posted: Fri Dec 12, 2003 2:52 pm Post subject: |
Hei
I have made at bluetooth connection from GPS to PDA, and theis conncetion is OK.
But in TomTom i just can thouse Serial cable on com 0 - com3 - serial cable on com6 - native ir - usb cable - seriel cable on com1
not com 8 :-(
I have try everything, maybe it is my PDA.. i will try to reinstall win 2003 on my PDA.and mybee com 8 wil come :-)
Darren wrote: | Have you 'discovered' the Bluetooth GPS in Bluetooth Manager? Doing this adds the COM8 BT Serial Port. The fact that you're not seeing this suggest you have not done this? |
gotskov Occasional Visitor
Posted: Fri Dec 12, 2003 6:31 pm Post subject: Hi Johnny. |
Its me, gotskov from www.it-svar.dk.
Noice to see you here.
I just remember i once tried at Socket bt gps".
I had to find satelits BEFORE my ipaq 2210 could find it. So try to put the gps somewhere with "clean" sky and let it find som sats. There "should be a light telling you when it has a fix. THEN try to get it connected to the ipaq. It worked for me!
Gotskov
Denmark |
Stevie Regular Visitor
Joined: 12/05/2003 21:08:16 Posts: 89 Location: United Kingdom
Posted: Fri Dec 12, 2003 7:37 pm Post subject: |
Not sure if it is the same but I upgraded my Ipaq 3970 to Pocket Pc 2003 and when I went to setup TomTom again I was suprised to find I needed to select 'Bluetooth Serial Port COM5:' after I had paired my BT308.
I expected it to be COM8 from memory. |
Posted: Mon Dec 15, 2003 2:51 pm Post subject: |
I just can those com 0-1-3-6 not 5 or 8 :-(
i thionk that my GPS just talt on com 8, and on my PDA 5450 i cant those com 8.
i try to reinstall my PDA with 2003
Stevie wrote: | Not sure if it is the same but I upgraded my Ipaq 3970 to Pocket Pc 2003 and when I went to setup TomTom again I was suprised to find I needed to select 'Bluetooth Serial Port COM5:' after I had paired my BT308.
