Pocket GPS World :: View topic - copying favorites on TOM TOM
dumbodick
PostPosted: Thu Jul 06, 2006 12:09 pm    Post subject: copying favorites on TOM TOM Reply with quote
I am using Tom Tom on another memory card on my PDA. I need to copy the favorites information from another system, is there a file i can bring across that has this info. It must be stored on the storage card somewhere but i cant find it.
regards DB
hope68
PostPosted: Thu Jul 06, 2006 1:33 pm    Post subject: Re: copying favorites on TOM TOM Reply with quote
regards DB
Hiya,
yes, you have to copy the xx-map.cfg file to the other storage card.
cu Peter
julianbarker
PostPosted: Thu Jul 06, 2006 1:35 pm    Post subject: Reply with quote
The best thing to do is always use a POI category instead of favourites as favourite info is easily lost and not easily moved from machine ot machine. The best thing is to create a POI category, move al lyour favourites to it, then move the POI file (the OV2 file with the same name as the category) to the other device. If you want to then convert the POIs back to favourites you can do, but you are more likely to lose the data if TT ever has problems reading the card.
hope68
PostPosted: Thu Jul 06, 2006 2:30 pm    Post subject: Reply with quote
Sorry, what is difficult when you copy and paste a file?
I also have a copy of my xx-map.cfg-fiel on my sd-card (and also on my pc). if the cfg-file ever gets corrupt - then i just copy and paste it into the map-file and i have the favorites, home etc. again.
cu Peter
dumbodick
PostPosted: Thu Jul 06, 2006 2:40 pm    Post subject: Reply with quote
thanks loads for the info, this site is so usefull.
db
PostPosted: Thu Jul 06, 2006 6:57 pm    Post subject: Reply with quote
The problem arises when there is an upgrade in Major Versions. Sometimes the cfg File is not compatible with the new Version.
Another advantage of using a Favourite POI is that it can be used on any TT and, with the POI Conversion Tools that are available, converted for use on most PND that have the capability to use custom POI.
hope68
PostPosted: Thu Jul 06, 2006 8:49 pm    Post subject: Reply with quote
Thx for the info
cu Peter
sHaRpEy
PostPosted: Thu Jul 06, 2006 9:32 pm    Post subject: Reply with quote
Superb! Thanks for the info. TomTom is cos once you create a favourite you can't see the address of GPS position data. Unless someone knows something I don't? Confused
PostPosted: Thu Jul 06, 2006 10:21 pm    Post subject: Reply with quote
I don't understand what you're asking for.Sad
What do you want to achieve?
sHaRpEy
PostPosted: Thu Jul 06, 2006 10:37 pm    Post subject: Reply with quote
Well if you've added a favourite, but later you won't to know the detials, ie: address/postcode you are unable to see this information. Only options are to rename or delete.
PostPosted: Fri Jul 07, 2006 7:17 am    Post subject: Reply with quote
You could put those details in the Text when you originally name the Favourite.
If it is a Favourite, would you need to know the extra information?
vocaro
PostPosted: Thu Jul 20, 2006 12:21 am    Post subject: How to extract GPS coordinates from TomTom Navigator 5 Reply with quote
Hope this helps.
neil01
PostPosted: Thu Jul 20, 2006 5:48 pm    Post subject: Reply with quote
Oldboy wrote:
...If it is a Favourite, would you need to know the extra information?
Perhaps not for you, but you may be using collected favourites from several sources to create a POI file for everyone. Deliveries springs to mind as an example.
Pedro-G
PostPosted: Tue Jul 25, 2006 10:55 pm    Post subject: Reply with quote
In case someone is interested, I just changed my old Scandinavia map to the Scandinavia Plus (v632). I managad to rescue my favourites by copying the .cfg file. Naturally I had to rename it to "_Plus-Map", but it was still compatible.
The only thing I lost was my Home address, but it took about 2 seconds to re-enter that... Smile
However, going with a POI category instead of favourites sounds good, I might do that.
