Pocket GPS World :: View topic - Bluetooth pairing/serial port setting on ipaq 1940
scoobysi
PostPosted: Thu Dec 11, 2003 10:58 pm    Post subject: Bluetooth pairing/serial port setting on ipaq 1940 Reply with quote
Hi there,
I've a new 1940 and TomTom software and GPS bluetooth kit, and i'm having problems getting the GPS to connect with the ipaq.
I've done the pairing, seen the bluetooth light go constant blue on the GPS arial, tried to change the serial port to COM5 as instructed on tomtom.com - but it won't let me tick the checkbox - only on COM8.
basically, i can't get the ipaq's gps to operate; please help!!! Crying or Very sad
many thanks Thumbs Up
si
PostPosted: Thu Dec 11, 2003 11:36 pm    Post subject: Reply with quote
Not sure why the TomTom are telling you to use COM5, the BT COM port is invariably COM8, try it on this and see if you get communication with the GPS?
scoobysi
PostPosted: Thu Dec 11, 2003 11:55 pm    Post subject: Reply with quote
i think i'm having problems because the beam is switched on to recieve - just can't seem to turn it off, though Rolling Eyes any ideas?
cheers
si
PostPosted: Fri Dec 12, 2003 9:01 am    Post subject: Reply with quote
Start | Settings | Connections | Beam - Untick receive all incoming beams?
scoobysi
PostPosted: Sat Dec 13, 2003 2:28 am    Post subject: Reply with quote
there's no tick box against 'receive all incoming beams' - can't change it - take it there should be something there to change this setting?
its just a white screen with a single line near the top underneath the black line below beam....
now, has it screwed up?
si
scoobysi
PostPosted: Sat Dec 13, 2003 2:54 am    Post subject: Reply with quote
ok now the beam is turned off - don't know how, just reset the ipaq (tried this before but didn't work) and its stopped the beam connection, and now gps is turned on... but still not picking up Sad
scoobysi
PostPosted: Sat Dec 13, 2003 3:15 am    Post subject: Reply with quote
think the software is screwed up - the check boxes keep apearing and disapearing, and now the beam is turned on again Rolling Eyes back to dixons....
vanstmic
PostPosted: Sun Dec 14, 2003 5:06 pm    Post subject: Reply with quote
scoopy, did you get anywhere with this? i think i am having the same problem??
scoobysi
PostPosted: Sun Dec 14, 2003 10:17 pm    Post subject: Reply with quote
global reset mate - did the trick. press the reset button on the side AND hold down the power button at the top - it resets the pda to factory settings, and the check boxes should all be ok. of course, you loose everything thats on there, but it solves the problem and the tomtom navigation works a treat now.
cheers
si
vanstmic
PostPosted: Mon Dec 15, 2003 11:26 am    Post subject: Reply with quote
so was the problem linked to the beam??
scoobysi
PostPosted: Mon Dec 15, 2003 8:19 pm    Post subject: Reply with quote
dunno, overall software problem that was solved by resetting the thing - the main problem was the absence of the check boxes, mainly not being able to turn off the beam and select com 5 for the gps
22.094 (25 Sep 24)
