Pocket GPS World :: View topic - Tom Tom Postcode configuring
bazburns
PostPosted: Mon Jul 03, 2006 12:41 pm    Post subject: Tom Tom Postcode configuring Reply with quote
My TomTom will only recognise the first 4 digits of a postcode. Can i change this anywhere in a file to accept the full post code?
I remember reading about this same issue last year, but ignored it at the time. Can anyone assist me and guide me through the sequence as i an not overly confident on changing scripts in files etc!! Embarassed
alix776
PostPosted: Mon Jul 03, 2006 1:05 pm    Post subject: Reply with quote
are you using the postcode option in the menu. in v5.0 you had to put an empty folder called tomtom in the root of the sd card but the lastest version fixed that
device Lumia 950 xl
bazburns
PostPosted: Mon Jul 03, 2006 1:11 pm    Post subject: Reply with quote
Yes when i use the postcode function it only accepts the first 4 digits. Can you help?
julianbarker
PostPosted: Mon Jul 03, 2006 2:04 pm    Post subject: Reply with quote
Are you using postcodes in the standard address search? In which case you will get four digit codes.
If on the other hand you go to the next page you wil be able to access the full postcode search which runs to the full length of the code.
To use the full postcode you need the GB postcode database installed from the disk or whatever, and you need the blank folder mentioned by the other poster.
bazburns
PostPosted: Mon Jul 03, 2006 6:19 pm    Post subject: Reply with quote
Have placed an empty folder called TOMTOM in the SD card. All works a treat now!!!
Great response from GPS world thanks.
AlastairmX1
PostPosted: Fri Jul 07, 2006 9:00 am    Post subject: Reply with quote
I've been using the TomTom Nav 5 upgrade on my Palm T5 since it's release. I've put empty files names 'tomtom' all over the SD card but the postcode search still doesn't work.
This maybe because there are other problems with the application. It crashes alot and I repeated have to enter the activation code. I can get the french maps to work. TomTom's support is useless and they haven't replied to me in 6 months. All suggestions greatfully received.
alix776
PostPosted: Fri Jul 07, 2006 9:21 am    Post subject: Reply with quote
did you install the ZIP file when you installed the map to the sd card
device Lumia 950 xl
AlastairmX1
PostPosted: Fri Jul 07, 2006 8:09 pm    Post subject: Reply with quote
errr... not sure. Which .zip file should be there?
PostPosted: Fri Jul 07, 2006 10:59 pm    Post subject: Reply with quote
The File is Great_Britain.Postal and it's in the Zip Folder. The Folder is in the Root of the SD Card.
The same place as the empty tomtom Folder should be.
Border_Collie
PostPosted: Sat Jul 08, 2006 12:20 am    Post subject: Reply with quote
Sometimes you can get really bogged down by trying to find the problem
Why not do a hard re-set and re-install from scratch with your original CD's.
When I installed my GB map the Postcode ZIP folder was installed automatically several seconds later. Just leave it until it's finished.
Remember to leave the ZIP folder intact. Add the empty folder and name it tomtom, then update any available software from the TT site.
When you fisrt try to use the map you will have to activate it again. Have your product code ready and when prompted choose Auto.
AlastairmX1
PostPosted: Sun Jul 09, 2006 4:21 pm    Post subject: Reply with quote
Ahh.. yes. THe hard reset and reinstall sounds a good option. However I've got loads of other application and data on the T5 and re-installin gall that would be complcated. Is there a short route to uninstalling the TomTom software and reinstalling it?
AlastairmX1
Thanks for the reply and help.
MarcusWhite
PostPosted: Wed Jul 12, 2006 12:29 pm    Post subject: Reply with quote
I've copied the postal file into the great_britain folder with no luckon the SD card. I have also copied the zip file into the great_britain folder with no luck. I have copied these into a blank folder (named TomTom), and into sd card without putting either the postal file or the zip folder with the postal file into any other folder.
Still no luck....
PostPosted: Wed Jul 12, 2006 6:43 pm    Post subject: Reply with quote
Still no luck....
The Postcode File named Great_Britain.postal is place in the Zip Folder.
The Zip Folder is placed in the Root of the SD Card. It's the highest level you can get on the Card.
If you use the TT install method it will automatically put it in the right place.;)
