Mullet Frequent Visitor
Posted: Sun Jun 25, 2006 6:10 pm Post subject: Re: More Memory |
Svengali_uk wrote: |
Incidentaly - the new warning files work perfectly! |
Enjoy  |
id Occasional Visitor
Posted: Fri Jun 30, 2006 7:55 am Post subject: Spoken Announcements for POI on TT1 |
Works great but really struggle with the loss of all POI Chimes. I think it migh have been useful to keep one free for other POI's and therefore the Polite 3 might have been better used. Akso I find that Beep one contains A vhime and the work 'Gatso', I am not sure whether this is deliberate or an error. |
Svengali_uk Occasional Visitor
Posted: Fri Jun 30, 2006 8:47 am Post subject: |
Hi id, just to pass on to you what I have learned over the past few days, the sound file add-on listed on this site is very limited, but I was given a sound folder by Mullet which contained 32 sound warnings, each of which was preceeded by an un-missable siren!
If you can get a copy from Mullet, don't try to install it over the sound files that you already have - mis-listing results. Restore your data.chk file to one which has just the original TomTom sound files, then use POI Extended Capture (Sorry, can't find the link) to build a customised sound file.
Works like a charm - and 32 different warnings should be enough for anyone! |
Andy_P Pocket GPS Moderator
Posted: Fri Jun 30, 2006 7:42 pm Post subject: |
I thought that at first, but take a close look at the Qty of warnings? - POIExtend only goes to 30 not 32 as stated - what application was used to create 32 specific warnings and where from? - Mike |
Posted: Fri Jun 30, 2006 8:01 pm Post subject: |
mikealder wrote: | I thought that at first, but take a close look at the Qty of warnings? - POIExtend only goes to 30 not 32 as stated - what application was used to create 32 specific warnings and where from? - Mike |
It is indeed to 30 slot POIExtend, I gave svengali_UK 32 soundfiles (and rays licence) but only 24 needed for the full speed cam warnings, the rest are options. |
garyowens Occasional Visitor
Posted: Fri Jun 30, 2006 8:22 pm Post subject: poi voice warnings for speed cams |
well It seems I cannot get the voices to work on my ipaq running win mobile5 my device lists is as follows pocketpc device app vers 5.000(4890) great britain map v562 .Downloade and replaced the chk file but still get the horns and whistles, Also downloaded and put on my other device nokia 6630 with no problems, can any one advise me please?? thanks in advance Gary, garyowens1@ntlworld.com |
rayflan Frequent Visitor
Posted: Fri Jun 30, 2006 8:28 pm Post subject: |
Have you changed the right data.chk file ?. the one you need to change is on your device in Program Files | Navigator folder and not the one on the sdcard. _________________ Ray
New Url www.tomtomsatnav.info
Visit my site |
Posted: Sat Jul 01, 2006 12:02 am Post subject: Spoken POI alerts |
Used the link as advised. Dead Easy. Thanks for that I am well pleased. Got my voice alerts and still some left over for chimes. :D |
fatmanscoop Regular Visitor
Joined: Jul 07, 2005 Posts: 244 Location: Nottingham...
Posted: Mon Jul 03, 2006 3:16 pm Post subject: |
does anyone know when there will be a spokern alert for firmware v6 _________________ Garmin xt mobile
Nokia N96
Liverpool F.C rocks |
forky Lifetime Member
Mac-The-Knife Occasional Visitor
Posted: Thu Jul 06, 2006 7:00 pm Post subject: |
Excellent resource!
I have just downloaded camera POI database and new sounds for my MIO A701 with TomTom Navigator 5 App version 5.210 (5430). All the POIs are loaded fine but I still get the old sounds instead of the spoken ones, e.g. "Gatso 40" etc. I replaced my data.chk file with the download from the site for '5430' but cannot see what I have ommitted.
Can anyone please suggest what Muppetry I may have done to not get the appropriate sounds?
All help will be much appreciated.
Many thanks... |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Thu Jul 06, 2006 7:15 pm Post subject: |
Mac-The-Knife wrote: | I have just downloaded camera POI database and new sounds for my MIO A701 with TomTom Navigator 5 App version 5.210 (5430). | There are 2 builds with 5.21. 5430 and 5431. Check to make sure you have the right one.
Mac-The-Knife wrote: | All the POIs are loaded fine but I still get the old sounds instead of the spoken ones, e.g. "Gatso 40" etc. I replaced my data.chk file with the download from the site for '5430' but cannot see what I have ommitted. | If you have the right file, it will go into My Device/Program Files/Navigator. It doesn't go on the SD Card. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Thu Jul 06, 2006 7:45 pm Post subject: |
You might need to "soft reset" the device to get the unit to load the new data.chk file and use it, this will only restart the device - give the reset hole a prod with the stylus and then try configuring the warnings, if you have put the file where Old Boy has explained then it should work - Mike |
Posted: Thu Jul 06, 2006 8:06 pm Post subject: |
Thanks Oldboy, it is 5430. |
