Pocket GPS World :: View topic - trouble exporting routes
boggy
PostPosted: Thu Jun 29, 2006 9:00 pm    Post subject: trouble exporting routes Reply with quote
After successfully building a route on the PC and then exporting to the Quest can anyoneplease explain why Quest now comes back with message "This route does not match the available maps. It will not follow the roads precisely. Do you want to recalculate it?"
Not had this problem before.
any advice appreciated.
oddsock
PostPosted: Thu Jun 29, 2006 10:23 pm    Post subject: Reply with quote
You usually get that message when the route goes through areas where you have not loaded all the the map segments into the Quest and its using the base map instead. ..
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
Kritou
PostPosted: Thu Jun 29, 2006 11:10 pm    Post subject: Reply with quote
Also check that in the map pane in Mapsource all the maps tiles are of the same version
It can also happen if you have used a POI as a starting point rather than a hard waypoint. The Quest will then attempt to build a route from where it last knew it was through this POI, which is effectively a via or mapoint
boggy
PostPosted: Fri Jun 30, 2006 12:01 am    Post subject: Reply with quote
Thanks . I'll do some further investigation, although this problem has never ocurred before...
22.063 (19 Jun 24)
